Air - Prandtl Number
The Prandtl Number - Pr - is a dimensionless number approximating the ratio of momentum diffusivity (kinematic viscosity) to thermal diffusivity - and is often used in heat transfer and free and forced convection calculations.
The Prandtl number can for calculations be expressed as
Pr =  μ cp / k                           (1)
μ = absolute or dynamic viscosity (kg/(m s), (lbm/(ft h))
cp = specific heat (J/(kg K)), (Btu/lbmoF)
k = thermal conductivity (W/(m K)), (Btu/(h ft2oF/ft))
Below, Prandtl numbers for air at varying temperatures and pressures are given in figures and tables.
See also other properties of Air at varying temperature and pressure: Density and specific weight at varying temperature, Density at varying pressure, Diffusion Coefficients for Gases in Air, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Conductivity, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air thermophysical properties at standard conditions and Composition and molecular weight,
as well as Prandtl number of Ammonia, Carbon dioxide, Methane, Nitrogen, Propane and Water .
Air Prandtl number at 1 bara pressure, temperature given as °C or °F:
Air Prandtl number at varying temperatures and constant pressures, SI and Imperial units:
Air - Prandtl Number at 1 bara Pressure
Temperature Pr Temperature Pr
(°C) (-) (°F) (-)
-100 0.734 -150 0.733
-50 0.720 -50 0.719
0 0.711 0 0.714
25 0.707 60 0.709
50 0.705 75 0.708
100 0.701 100 0.706
150 0.699 200 0.701
200 0.698 300 0.699
250 0.699 400 0.698
300 0.702 500 0.700
Air Prandtl number at given temperatures and 1, 5 10 and 20 bara pressure:
Temperature Prandtl number at given pressures
(K)(°C)(°F) 1 bara,
14.5 psia
5 bara,
72.5 psia
10 bara,
145 psia
20 bara,
725 psia
60 -213.2 -351.7 4.138 4.153 4.170 4.187
80 -193.2 -315.7 1.7 2.252 2.259 2.269
100 -173.2 -279.7 0.780 0.898 1.783 1.770
120 -153.2 -243.7 0.759 0.806 0.890 1.360
140 -133.2 -207.7 0.747 0.773 0.812 0.923
180 -93.2 -135.7 0.731 0.743 0.759 0.792
200 -73.2 -99.7 0.726 0.735 0.745 0.769
220 -53.2 -63.7 0.721 0.728 0.736 0.754
240 -33.2 -27.7 0.717 0.722 0.729 0.742
260 -13.2 8.3 0.713 0.718 0.723 0.734
273 0.0 32.0 0.711 0.715 0.720 0.729
280 6.9 44.3 0.710 0.714 0.718 0.727
289 15.6 60.0 0.709 0.713 0.716 0.723
300 26.9 80.3 0.707 0.711 0.714 0.722
320 46.9 116.3 0.705 0.708 0.711 0.717
340 66.9 152.3 0.703 0.705 0.708 0.714
360 86.9 188.3 0.701 0.703 0.706 0.711
380 106.9 224.3 0.700 0.702 0.704 0.709
400 126.9 260.3 0.699 0.701 0.703 0.706
500 226.9 440.3 0.698 0.700 0.701 0.703
600 326.9 620.3 0.703 0.704 0.704 0.706
700 426.9 800.3 0.710 0.710 0.711 0.712
800 526.9 980.3 0.717 0.718 0.718 0.719
900 626.9 1160.3 0.724 0.725 0.725 0.725
1000 726.9 1340.3 0.730 0.730 0.730 0.731
1100 826.9 1520.3 0.734 0.735
1500 1226.9 2240.3 0.743 0.743
1900 1626.9 2960.3 0.742 0.742
Air Psychrometrics
Fluid Mechanics
Gases and Compressed Air
Material Properties
Air - Humidity Ratio
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties - SI Units
Ideal gas properties of air at low pressure - SI units.
Air Properties: Temperature, Pressure & Density Data
Pressure loss in compressed air pipe lines.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Propane - Thermal Diffusivity vs. Temperature and Pressure
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
