Air - Speed of Sound vs. Temperature
Speed of Sound in Air at Standard Atmospheric Pressure - Imperial (BG) Units:
Temperature - t - (oF) | Speed of Sound - c - (ft/s) |
-40 | 1004 |
-20 | 1028 |
0 | 1051 |
10 | 1062 |
20 | 1074 |
30 | 1085 |
40 | 1096 |
50 | 1106 |
60 | 1117 |
70 | 1128 |
80 | 1138 |
90 | 1149 |
100 | 1159 |
120 | 1180 |
140 | 1200 |
160 | 1220 |
180 | 1239 |
200 | 1258 |
300 | 1348 |
400 | 1431 |
500 | 1509 |
750 | 1685 |
1000 | 1839 |
1500 | 2114 |
Speed of Sound in Air at Standard Atmospheric Pressure - SI Units:
Temperature - t - (oC) | Speed of Sound - c - (m/s) |
-40 | 306.2 |
0 | 331.4 |
5 | 334.4 |
10 | 337.4 |
15 | 340.4 |
20 | 343.3 |
25 | 346.3 |
30 | 349.1 |
40 | 354.7 |
50 | 360.3 |
60 | 365.7 |
70 | 371.2 |
80 | 376.6 |
90 | 381.7 |
100 | 386.9 |
200 | 434.5 |
300 | 476.3 |
400 | 514.1 |
500 | 548.8 |
1000 | 694.8 |
Speed of Sound in Air and Relative Humidity
Temperature (°C) | Speed of Sound (m/s) | ||||||||
Relative Humidity (%) | |||||||||
10 | 20 | 30 | 40 | 50 | 60 | 70 | 80 | 90 | |
0 | 331.5 | 331.5 | 331.5 | 331.6 | 331.6 | 331.6 | 331.7 | 331.7 | 331.7 |
5 | 334.5 | 334.6 | 334.6 | 334.7 | 334.7 | 334.7 | 334.8 | 334.8 | 334.9 |
10 | 337.5 | 337.6 | 337.7 | 337.7 | 337.8 | 337.9 | 337.9 | 338.0 | 338.0 |
15 | 340.5 | 340.6 | 340.7 | 340.8 | 340.9 | 341.0 | 341.1 | 341.2 | 341.2 |
20 | 343.5 | 343.6 | 343.7 | 343.9 | 344.0 | 344.1 | 344.2 | 344.4 | 344.5 |
25 | 346.4 | 346.6 | 346.8 | 347.0 | 347.1 | 347.3 | 347.5 | 347.6 | 347.8 |
30 | 349.4 | 349.6 | 349.9 | 350.1 | 350.3 | 350.5 | 350.8 | 351.0 | 351.2 |
Calculate the Speed of Sound in Air vs. Temperature
The velocity of sound can be calculated in metric units as
vms = 20.05 (273.16 + tC)1/2 (1)
vms = velocity of sound (m/s)
tC = temperature (°C)
Velocity of sound in Imperial units:
vfts = 49.03 (459.7 + tF)1/2 (2)
vfts = velocity of sound (ft/s)
tF = temperature (°F)
Note that speed is a scalar quantity. Velocity is vector quantity with direction.
• Acoustics
• Gases and Compressed Air
Acoustic Impedance
Specific acoustic impedance is measure of the ability of a medium to transmit sound waves.
Air - Prandtl Number
Air Properties: Temperature, Pressure & Density Data
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Liquids - Speed of Sound
Speed of sound in common fluids like water, glycerol, kerosene and more.
Mach Number
An introduction to the Mach Number.
Seawater - Attenuation of Sound
Attenuation of sound in seawater vs. temperature and frequency.
Solids and Metals - Speed of Sound
Speed of sound in solids and metals like aluminum, brass, concrete and more.
Sound - Attenuation and Speed vs. Sound Frequency and Air Humidity
The speed and attenuation of sound in moist air varies with sound frequency and air humidity.
Sound - Doppler Effect
The doppler effect is the change in sound frequency due to the relative motion between a source and a listener.
An introduction to the nature of sound with frequencies, wave-lengths and octaves.
Sound Intensity
Acoustic power of sound per unit area.
Speed of Sound - Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Speed of Sound - Online Calculator
A free online speed of sound calculator.
Speed of Sound vs. Elevation, Temperature and Air Pressure
Altitude and speed of sound, temperature and pressure.
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
Water - Speed of Sound vs. Temperature
Speed of sound in water at temperatures ranging 32 - 212°F (0 - 100°C) - Imperial and SI units.
