Sound Intensity
Sound Intensity
The sound intensity is the sound power transmission through a surface (W/m2) - a vector quantity with direction through a surface.
I = P / A                                             (1)
I = sound intensity (W/m2)
P = sound power through surface area (W)
A = surface area (m2)
In a sound field the Intensity can be expressed as
I = (p2 / ρ) c
  = v2 ρ c                                         (1b)
p = sound pressure (Pa)
ρ = density (kg/m3)
c = velocity of sound (m/s)
v = particle velocity (m/s)
Sound Intensity Level
The dynamic range of human hearing and sound intensity spans from 10-12 W/m2 to 10 - 100 W/m2. The highest sound intensity possible to hear is 10,000,000,000,000 times as loud as the quietest!
This span makes absolute values for sound intensity impractical in normal use. A more convenient way to express sound intensity is the relative logarithmic decibel scale with reference to the lowest human hearable sound - 10-12 W/m2 (0 dB).
Note! In U.S. the reference 10-13 watts/m2 is commonly used.
Sound Intensity Level can be expressed as:
LI = 10 log(I / Iref)
   = 10 log10(I) + 120                              (2)
LI = sound intensity level (dB)
Iref = 10-12 - reference sound intensity - the threshold of hearing (W/m2)
The logarithmic sound intensity level scale match the human sense of hearing. Doubling the intensity increases the sound level with 3 dB(10 log(2)).
The Decibel Scale
Example - Sound Intensity
The difference in dB for intensity 10-8 watts/m2 and 10-4 watts/m2 (10000 units) can be calculated  as
ΔLI = 10 log((10-4 watts/m2) / (10-12 watts/m2)) - 10 log((10-8 watts/m2) / (10-12 watts/m2))
= 40 dB
Increasing the sound intensity by a factor of
  • 10 raises its level by 10 dB
  • 100 raises its level by 20 dB
  • 1000 raises its level by 30 dB
  • 10000 raises its level by 40 dB
  • and so on
Note! Since the sound intensity level may be difficult to measure it is common to use sound pressure level measured in decibels instead. Note that doubling sound pressure raises the sound pressure level with 6 dB.
Loudness
Sound loudness is a subjective term describing the ear's perception of a sound.
Sound intensity and feeling of loudness:
  • 110 to 225 dB - Deafening
  • 90 to 100 dB - Very Loud
  • 70 to 80 dB - Loud
  • 45 to 60 dB - Moderate
  • 30 to 40 dB - Faint
  • 0 - 20 dB - Very Faint
Sound Power, Intensity and Distance to Source
Sound intensity decreases with the distance to the source. Sound intensity vs. distance can be expressed:
I = N / 4 πr2                                   (3)
Nsound power (W)
π = 3.14
r = radius or distance from source (m)
Sound Intensity and Sound Pressure
The relation between Sound Intensity and Sound Pressure can be expressed as
I = p2 / ρ c                                (4)
ρ = density air (1.2 kg/m3 at 20 oC)
c = speed of sound (331 m/s)
The relation between Sound Intensity Level and Sound Pressure Level  is
LI = Lp - 0.2                  (5)
Lp = sound pressure level (dB)
Acoustics
Noise and Attenuation
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Human Effects when Exposed to Low-Frequency Noise or Vibration
Physiological effects from low-frequency noise or vibrations.
Phonetic Alphabet
The phonetic alphabet used in international aircraft communications.
Propagation of Sound Indoors - the Room Constant
In a room the sound or noise will reach the receiver as direct and reverberant sound.
Sound - Abatement vs. the Distance from Source
The disruption of the sound pressure wave and the reduction of noise is called attenuation - Sound Pressure Level vs. distance calculator.
Sound - Hearing Threshold vs. Age
Shift in hearing threshold for men and women vs. age.
Sound Power
