The Decibel
Decibel is a logarithmic unit used to describe ratios of physical values like - like power, sound pressure, voltage, intensity and more.
The decibel can be expressed as:
L = 10 log(S / Sref)                                        (1)
L = signal level (dB)
S = signal (signal unit)
Sref = signal reference (signal unit)
The Decibel Scale
Sound Power Level
Sound power is the energy rate - the energy of sound per unit of time (J/s, W in SI-units) from a sound source.
Sound power can more practically be expressed in a logarithmic scale named Sound Power Level as the ratio of sound power to the sound power at the threshold of hearing - 10-12 W:
LN = 10 log(N / Nref)                                   (2)
LN = Sound Power Level (decibel, dB)
N = sound power (W)
Nref = reference sound power (10-12 W)
  • The lowest sound power persons with excellent hearing can discern is about 10-12 W -  defined as 0 dB in the decibel scale
  • The loudest sound power generally possible to encounter is that of a jet aircraft with a sound power of 105 W - 170 dB
Sound Intensity Level
Sound intensity is the ratio acoustic or sound power to area. The SI-unit for Sound Intensity is W/m2
The Sound Intensity Level can be expressed as:
LI = 10 log(I / Iref)                                (3)
LI = sound intensity level (dB)
I = sound intensity (W/m2)
Iref = 10-12 - reference sound intensity (W/m2
Sound Pressure Level
The sound pressure is the force (N) of a sound on a surface area (m2) perpendicular to the direction of the sound. The SI-unit for the Sound Pressure is N/m2 or Pa.
The Sound Pressure Level in decibel can be expressed as
Lp = 10 log(p2 / pref2)
    = 10 log(p / pref)2
    = 20 log(p / pref)                                  (4)
Lp = sound pressure level (dB)
p = sound pressure (Pa)
pref = 2×10-5 - reference sound pressure (Pa)
  • If the pressure is doubled the sound pressure level is increased with 6 dB (20 log(2))
Acoustics
Noise and Attenuation
Physiology
Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Decibel A, B and C
Noise - Acceptable dBA Level
Noise Criterion (NC) Levels: Definitions, Standards & Calculator
Noise Criterion - NC - level is a standard uesd to describe the relative loudness of a space within a range of frequencies.
Noise Exposure - NIOSH Permissible Levels and Duration
Exposure to noise should be controlled so that it is less than a maximum combination of exposure level and duration.
Noise generated in Blade Dampers
Sound power noise generated by blade dampers in ventilation systems.
NR - the Noise Rating Curve
The Noise Rating (NR) Curve used to determine acceptable indoor environments for hearing preservation, speech communication and annoyance.
Phonetic Alphabet
The phonetic alphabet used in international aircraft communications.
Signals - Adding Decibels
Sound - Hearing Threshold vs. Age
Shift in hearing threshold for men and women vs. age.
Sound Intensity
Acoustic power of sound per unit area.
Sound Power
Subjective Effect of Change in Sound Pressure Level
Change in sound pressure level and the subjective human perception.
