Hydrocarbons - Vapor Pressures
Vapor pressure versus temperature for the hydrocarbons propane, n-butane, n-pentane and n-heptane:
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Flash Points - Liquids
The flash points for some common liquids and fuels.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Propane - Vapor Pressure vs. Temperature
Vapor pressure vs. temperature.
