Propane - Vapor Pressure vs. Temperature
The vapor pressure of propane (C3H8) depends on the temperature. Vapor pressure of 100% propane:
Note! The metric chart indicates gauge pressure. The Imperial chart indicates absolute pressure . Imperial gauge pressure can be calculated as
psig = psia - (14.7 psi) (1)
See also other properties of Propane at varying temperature and pressure : Density and specific weight, Dynamic and Kinematic Viscosity, Prandtl number, Specific heat (heat capacity), Thermal conductivity and Thermal diffusivity, and Thermophysical properties at standard conditions.
• Combustion
Adiabatic Flame Temperatures
Adiabatic flame temperatures for hydrogen, methane, propane and octane - in Kelvin.
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Liquid Densities
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
LPG - Gas Properties
Liquefied Petroleum - LP - gas properties.
LPG Pipes - Pressure Loss vs. Gas Flow
Resistance and pressure loss in liquid LPG pipes.
LPG Tanks - Relief Valves Capacities
Required capacities of relief valves on LPG vaporizers and tanks.
Propane - Latent Heat of Vaporization vs. Temperature
Latent heat with vaporized propane.
Propane - Thermal Diffusivity vs. Temperature and Pressure
Propane Air Mixture
Energy content and specific gravity of propane air mixtures.
Propane Butane Mixture - Evaporation Pressure
Propane Gas - Sizing of Pipe Lines
