The molecular weight of a substance, also called the molar mass , M, is the mass of 1 mole of that substance, given in M gram.
In the SI system the unit of M is (kg/kmol) and in the English system the unit is (lb/lbmol), while in the cgs system the unit of M is (g/mol). Molecular weight is represented by the same number in all unit systems regardless of the system used. For this reason, in many cases the unit for the molecular weight is not mentioned; however, one must realize that it is not a dimensionless parameter.
The molecular weight of a pure compound is determined from its chemical formula and the atomic weights of its elements. The atomic weights of the elements found in organic substances are C = 12.011, H = 1.008, S = 32.065, O = 15.999, and N = 14.007.
Example: The molecular weight of ethanol (C2H5 OH)
To calculate the molecular weight of ethanol, the molecular weight of each atom in the molecule is summed:
Methanol = 2*12.011(kg/kmol) + 6*1.008(kg/kmol) + 1*15.999 (kg/kmol) = 46.069 (kg/kmol)
See also Physical data for hydrocarbons, Physical data for alcohols and carboxylic acids, Physical data for organic nitrogen compounds and Physical data for organic sulfur compounds
Substance |
Molecular Weight |
Acetylene, C2H2 | 26.038 |
Air | 28.966 |
Ammonia (R-717) | 17.02 |
Argon, Ar | 39.948 |
Benzene | 78.114 |
n - Butane, C4 H10 | 58.124 |
1,2 - Butadiene | 54.092 |
1-Butene | 56.108 |
cis -2-Butene | 56.108 |
trans-2-Butene | 56.108 |
Butylene | 56.06 |
Carbon Dioxide, CO2 | 44.01 |
Carbon Disulphide | 76.13 |
Carbon Monoxide, CO | 28.011 |
Chlorine | 70.906 |
Cyclohexane | 84.162 |
Cyclopentane | 70.135 |
n - Decane | 142.286 |
Deuterium | 2.014 |
2,3 - Dimetylbutane | 86.178 |
2,2 - Dimethylpentane | 100.205 |
Diisobutyl | 114.232 |
Duoderane | 170.21 |
Ethane, C2H6 | 30.070 |
Ethene | 28.05 |
Ethyl Alcohol | 46.07 |
Ethylbenzene | 106.168 |
Ethyl Chloride | 64.515 |
3 - Ethylpentane | 100.205 |
Ethylene, C2H4 | 28.054 |
Fluorine | 37.996 |
Helium, He | 4.002602 |
n - Heptane | 100.205 |
n - Hexane | 86.178 |
Hydrochloric Acid | 36.47 |
Hydrogen, H2 | 2.016 |
Hydrogen Chloride | 36.461 |
Hydrogen Sulfide | 34.076 |
Hydroxyl, OH | 17.01 |
Isobutane (2-Metyl propane) | 58.124 |
Isobutene | 56.108 |
Isooctane | 210.63 |
Isopentane | 72.151 |
Isoprene | 68.119 |
Isopropylbenzene | 120.195 |
Krypton | 83.80 |
Methane, CH4 | 16.043 |
Methyl Alcohol | 32.04 |
Methyl Butane | 72.15 |
Methyl Chloride | 50.488 |
Methylcyclohexane | 98.189 |
Methylcyclopentane | 84.162 |
2 - Methylhexane | 100.205 |
2 - Methylpentane | 86.178 |
Natural Gas | 19.00 |
Neon, Ne | 20.179 |
Neohexane | 86.178 |
Neopentane | 72.151 |
Nitric Oxide, NO | 30.006 |
Nitrogen, N2 | 28.0134 |
Nitrous Oxide, N2O | 44.013 |
n - Nonane | 128.259 |
n - Octane | 114.232 |
Oxygen, O2 | 31.9988 |
Ozone | 47.998 |
n - Pentane | 72.151 |
Pentylene | 70.08 |
Propane, C3 H8 | 44.097 |
Propene | 42.081 |
Propylene | 42.08 |
R-11 | 137.37 |
R-12 | 120.92 |
R-22 | 86.48 |
R-114 | 170.93 |
R-123 | 152.93 |
R-134a | 102.03 |
R-611 | 60.05 |
Styrene | 104.152 |
Sulfur | 32.02 |
Sulfur Dioxide (Sulphur Dioxide) | 64.06 |
Sulfuric Oxide | 48.1 |
Toluene, toluol | 92.141 |
Triptane | 100.205 |
Xenon | 131.30 |
o - Xylene, xylol | 106.168 |
Water Vapor - Steam, H2O | 18.02 |
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Compression and Expansion of Gases
Isothermal and isentropic gas compression and expansion processes.
Density of Gases
Fuel Gases - Flame Temperatures
Adiabatic flame temperatures for common fuel gases - propane, butane, acetylene and more - in air or oxygen atmospheres.
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Gases - Specific Heat and Individual Gas Constants
Hydrocarbons - Melting Point vs. Molecular Weight
Calculate melting point of hydrocarbons from molecular weight (molar mass).
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Methane (CH₄): Thermophysical Properties and Phase Diagram
Moist Air - Mole Fraction of Water Vapor
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Mole and the Avagadro's Number
The mole is the SI base unit for an amount of a substance.
Vapor and Steam
An introduction to vapor and steam.
