Butane - Thermophysical Properties
The phase diagram of butane is shown below the table.
Chemical, physical and thermal properties of n-Butane - C4 H10 :
(values at 25 oC (77 oF, 298 K) and atmospheric pressure)
Molecular Weight | 58.12 |
Specific Gravity, air = 1 | 2.07 |
Specific Volume (ft3/lb, m3/kg) | 6.5, 0.405 |
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) | 37.5, 604 |
Vapor pressure at 25 oC (psia, MN/m2) | 35.4, 0.244 |
Absolute Viscosity (lbm/ft s, centipoises) | 4.8×10-6, 0.007 |
Sound velocity in gas (m/s) | 216 |
Specific Heat - cp - (Btu/lb oF or cal/g oC, J/kgK) | 0.39, 1675 |
Specific Heat Ratio - cp/cv | 1.096 |
Gas constant - R - (ft lb/lb oR, J/kg oC) | 26.56, 143 |
Thermal Conductivity (Btu/hr ft oF, W/moC) | 0.01, 0.017 |
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF, oC) | 31.2, -0.4 |
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) | 165.6, 386000 |
Freezing or Melting Point at 1 atm (oF, oC) | -217, -138 |
Latent Heat of Fusion (Btu/lb, J/kg) | 19.2, 44700 |
Critical Temperature (oF, oC) | 306, 152 |
Critical Pressure (psia, MN/m2) | 550, 3.8 |
Critical Volume (ft3/lb, m3/kg) | 0.070, 0.0043 |
Flammable | yes |
Heat of combustion (Btu/ft3, Btu/lb, kJ/kg) | 3300, 21400, 49700 |
Follow the links below to get values for the listed properties of butane at varying pressure and temperature :
- Density and specific weight
- Dynamic and kinematic viscosity
- Specific heat (heat capacity)
- Thermal conductivity
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Butane is a gas at standard conditions. However, at lower temperature and/or high pressures the gas becomes a liquid or a solid.
The butane phase diagram shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the butane boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
Combustion Heat
Density of Gases
Flash Points - Liquids
The flash points for some common liquids and fuels.
Fuel Gases - Flame Temperatures
Adiabatic flame temperatures for common fuel gases - propane, butane, acetylene and more - in air or oxygen atmospheres.
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Higher Calorific Values of Common Fuels: Reference & Data
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
LPG - Gas Properties
Liquefied Petroleum - LP - gas properties.
Propane Butane Mixture - Evaporation Pressure
Substances Triple Points
Triple points for common substances.
