Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                                (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = (m g) / V
   = ρ g                                     (2)
Tabulated values of carbon dioxide density at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Carbon Dioxide Density Calculator
The calculator below can be used to estimate the density and specific weight of gaseous carbon dioxide at given temperature and pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
Choose the actual pressure:
See also other properties of Carbon dioxide at varying temperature and pressure: Dynamic and kinematic viscosity, Prandtl number, Specific heat (Heat capacity) and Thermal conductivity, and Thermophysical properties at standard conditions, as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water .
Density and specific weight of carbon dioxide at given temperatures and pressures:
(K) (°C) (°F) (MPa) (bara) (psia) (mol/dm3) (g/l)
(kg/m3)
(lbm/ft3) (sl/ft3 ×10-3) (N/m3) (lbf/ft3)
Gas 220 -53.2 -63.7 0.1 1 14.5 0.05542 2.439 0.1523 4.732 23.9 0.152
240 -33.2 -27.7 0.1 1 14.5 0.05063 2.228 0.1391 4.323 21.8 0.139
250 -23.2 -9.7 0.1 1 14.5 0.04854 2.136 0.1334 4.145 21.0 0.133
260 -13.2 8.3 0.1 1 14.5 0.04663 2.052 0.1281 3.982 20.1 0.128
280 6.9 44.3 0.1 1 14.5 0.04322 1.902 0.1187 3.690 18.7 0.119
300 26.9 80.3 0.1 1 14.5 0.04029 1.773 0.1107 3.440 17.4 0.111
320 47 116 0.1 1 14.5 0.03774 1.661 0.1037 3.223 16.3 0.104
340 67 152 0.1 1 14.5 0.03549 1.562 0.09751 3.031 15.3 0.0975
360 87 188 0.1 1 14.5 0.03349 1.474 0.09202 2.860 14.5 0.0920
400 127 260 0.1 1 14.5 0.03013 1.326 0.08278 2.573 13.0 0.0828
450 177 350 0.1 1 14.5 0.02658 1.170 0.07303 2.270 11.5 0.0730
500 227 440 0.1 1 14.5 0.02406 1.059 0.06611 2.055 10.4 0.0661
600 327 620 0.1 1 14.5 0.02005 0.8824 0.05509 1.712 8.65 0.0551
650 377 710 0.1 1 14.5 0.01851 0.8144 0.05084 1.580 7.99 0.0508
850 577 1070 0.1 1 14.5 0.01415 0.6226 0.03887 1.208 6.11 0.0389
1050 777 1430 0.1 1 14.5 0.01145 0.5040 0.03146 0.978 4.94 0.0315
Gas 233.03 -40.1 -40.2 1 10 145 0.5910 26.01 1.624 50.47 255 1.62
240 -33.2 -27.7 1 10 145 0.5649 24.86 1.552 48.24 244 1.55
250 -23.2 -9.7 1 10 145 0.5325 23.44 1.463 45.47 230 1.46
260 -13.2 8.3 1 10 145 0.5047 22.21 1.387 43.09 218 1.39
280 6.9 44.3 1 10 145 0.4590 20.20 1.261 39.19 198 1.26
300 26.9 80.3 1 10 145 0.4222 18.58 1.160 36.05 182 1.16
320 47 116 1 10 145 0.3915 17.23 1.076 33.43 169 1.08
340 67 152 1 10 145 0.3656 16.09 1.004 31.22 158 1.00
360 87 188 1 10 145 0.3433 15.11 0.9433 29.32 148 0.943
400 127 260 1 10 145 0.3063 13.48 0.8415 26.16 132 0.842
450 177 350 1 10 145 0.2704 11.90 0.7428 23.09 117 0.743
500 227 440 1 10 145 0.2422 10.66 0.6655 20.68 105 0.665
600 327 620 1 10 145 0.2010 8.845 0.5522 17.16 86.7 0.552
650 377 710 1 10 145 0.1853 8.154 0.5090 15.82 80.0 0.509
850 577 1070 1 10 145 0.1413 6.219 0.3882 12.07 61.0 0.388
1050 777 1430 1 10 145 0.1143 5.030 0.3140 9.760 49.3 0.314
Liquid 250 -23.2 -9.7 5 50 725 24.06 1059 66.10 2055 10384 66.1
287.43 14.3 57.7 5 50 725 18.80 827.3 51.65 1605 8113 51.6
Gas 287.43 14.3 57.7 5 50 725 3.560 156.67 9.781 304.0 1536 9.78
450 177 350 5 50 725 1.416 62.30 3.889 120.9 611 3.89
650 377 710 5 50 725 0.9298 40.92 2.555 79.40 401 2.55
850 577 1070 5 50 725 0.7024 30.91 1.930 59.98 303 1.93
1050 777 1430 5 50 725 0.5666 24.93 1.557 48.38 245 1.56
Liquid 250 -23.2 -9.7 10 100 1450 24.46 1076 67.20 2089 10556 67.2
Supercritical phase 450 177 350 10 100 1450 2.991 131.6 8.218 255.4 1291 8.22
650 377 710 10 100 1450 1.863 82.00 5.119 159.1 804.1 5.12
850 577 1070 10 100 1450 1.393 61.31 3.827 119.0 601 3.83
1050 777 1430 10 100 1450 1.121 49.31 3.078 95.68 484 3.08
Supercritical phase 250 -23.2 -9.7 100 1000 14504 28.08 1236 77.13 2397 12117 77.1
450 177 350 100 1000 14504 19.25 847.0 52.88 1643 8306 52.9
650 377 710 100 1000 14504 13.68 601.9 37.58 1168 5903 37.6
850 577 1070 100 1000 14504 10.64 468.1 29.22 908.2 4590 29.2
1050 777 1430 100 1000 14504 8.793 387.0 24.16 750.8 3795 24.2
Density units conversion:
Density converter
Densities
Fluid Mechanics
Material Properties
Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Carbon Dioxide Gas - Ideal Properties
Enthalpy, Entropy and Internal Energy of Carbon Dioxide gas.
CO2 Calculator - Emissions from Trains
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
