Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                      (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = m g / V
   = ρ g                      (2)
Tabulated values of helium density at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Helium phase diagram
Online Helium Density Calculator
The calculator below can be used to estimate the density and specific weight of helium at given temperature and pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
Choose the actual unit of temperature: Choose the actual pressure: 1 bara / 14.5 psia; 10 bara / 145 psia; 50 bara / 725 psia;
See also Helium Thermophysical properties at standard conditions, as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water .
Density and specific weight of helium gas at varying temperature and atmospheric pressure, SI and Imperial units:
Density of helium at varying temperature and pressure, SI and Imperial units:
Density of helium at varying temperature and equilibrium pressure, SI and Imperial units:
Density and specific weight of helium at given temperatures and pressures:
(K) (°C) (°F) (bara) (psia) (mol/dm3) (g/l),
(kg/m3)
(lb/ft3) (sl/ft3) (N/m3) (lbf/ft3)
Liquid at
equilibrium
2.177 -270.97 -455.75 0.0486 0.704 36.53 146.2 9.127 0.2837 1434 9.127
2.5 -271 -455 0.100 1.45 36.23 145.0 9.052 0.2813 1422 9.052
3 -270 -454 0.237 3.44 35.30 141.3 8.821 0.2742 1386 8.821
3.5 -270 -453 0.466 6.76 34.00 136.1 8.496 0.2641 1335 8.496
4 -269 -452 0.810 11.7 32.20 128.9 8.047 0.2501 1264 8.047
4.5 -269 -452 1.29 18.7 29.68 118.8 7.416 0.2305 1165 7.416
5 -268 -451 1.95 28.2 25.18 100.8 6.293 0.1956 988.5 6.293
5.195 -267.96 -450.32 2.275 33.0 21.39 69.64 4.347 0.1351 682.9 4.347
Gas at
equilibrium
2.177 -270.97 -455.75 0.0486 0.704 0.2863 1.146 0.072 0.00222 11.24 0.07154
2.5 -271 -455 0.100 1.45 0.5287 2.116 0.1321 0.00411 20.75 0.1321
3 -270 -454 0.237 3.44 1.106 4.428 0.2764 0.00859 43.42 0.2764
3.5 -270 -453 0.466 6.76 2.004 8.022 0.5008 0.01557 78.67 0.5008
4 -269 -452 0.810 11.7 3.350 13.41 0.8372 0.02602 131.5 0.8372
4.5 -269 -452 1.29 18.7 5.436 21.76 1.358 0.04222 213.4 1.358
5 -268 -451 1.95 28.2 9.546 38.21 2.385 0.07414 374.7 2.385
5.195 -267.96 -450.32 2.28 33.0 17.40 69.64 4.347 0.1351 682.9 4.347
Gas
20 -253 -424 1 14.5 0.60 2.408 0.1503 0.00467 23.61 0.1503
40 -233 -388 1 14.5 0.30 1.200 0.07491 0.00233 11.77 0.07491
60 -213 -352 1 14.5 0.2000 0.8006 0.04998 0.00155 7.851 0.04998
80 -193 -316 1 14.5 0.1501 0.6007 0.03750 0.00117 5.891 0.03750
100 -173 -280 1 14.5 0.1201 0.4807 0.03001 9.33E-04 4.714 0.03001
120 -153 -244 1 14.5 0.10011 0.4007 0.02501 7.77E-04 3.930 0.02501
140 -133 -208 1 14.5 0.08582 0.3435 0.02144 6.67E-04 3.369 0.02144
160 -113 -172 1 14.5 0.07510 0.3006 0.01877 5.83E-04 2.948 0.01877
180 -93.2 -136 1 14.5 0.06676 0.2672 0.01668 5.18E-04 2.620 0.01668
200 -73.2 -100 1 14.5 0.06009 0.2405 0.01501 4.67E-04 2.358 0.01501
220 -53.2 -63.7 1 14.5 0.05464 0.2187 0.01365 4.24E-04 2.145 0.01365
240 -33.2 -27.7 1 14.5 0.05009 0.2005 0.01252 3.89E-04 1.966 0.01252
260 -13.2 8.3 1 14.5 0.04624 0.1851 0.01156 3.59E-04 1.815 0.01156
280 6.9 44.3 1 14.5 0.04292 0.1718 0.01073 3.33E-04 1.685 0.01073
300 26.9 80.3 1 14.5 0.04007 0.1604 0.01001 3.11E-04 1.573 0.01001
320 46.9 116 1 14.5 0.03758 0.1504 0.00939 2.92E-04 1.475 0.00939
340 66.9 152 1 14.5 0.03535 0.1415 0.00883 2.75E-04 1.388 0.00883
360 86.9 188 1 14.5 0.03340 0.1337 0.00835 2.59E-04 1.311 0.00835
400 127 260 1 14.5 0.03006 0.1203 0.00751 2.33E-04 1.180 0.00751
500 227 440 1 14.5 0.02405 0.09626 0.00601 1.87E-04 0.9440 0.00601
600 327 620 1 14.5 0.02004 0.08022 0.00501 1.56E-04 0.7867 0.00501
700 427 800 1 14.5 0.01718 0.06876 0.00429 1.33E-04 0.6743 0.00429
800 527 980 1 14.5 0.01503 0.06017 0.00376 1.17E-04 0.5901 0.00376
900 627 1160 1 14.5 0.01336 0.05348 0.00334 1.04E-04 0.5245 0.00334
1000 727 1340 0.01203 0.04814 0.00301 9.34E-05 0.4721 0.00301
Supercritical
phase
20 -253 -424 10 145 6.00 24.02 1.500 0.04661 235.6 1.500
40 -233 -388 10 145 2.93 11.72 0.7317 0.02274 114.9 0.7317
60 -213 -352 10 145 1.96 7.850 0.4901 0.01523 76.98 0.4901
80 -193 -316 10 145 1.477 5.912 0.3691 0.01147 57.98 0.3691
100 -173 -280 10 145 1.185 4.745 0.2962 0.00921 46.53 0.2962
120 -153 -244 10 145 0.9901 3.963 0.2474 0.00769 38.86 0.2474
140 -133 -208 10 145 0.8502 3.403 0.2124 0.00660 33.37 0.2124
160 -113 -172 10 145 0.7450 2.982 0.1862 0.00579 29.24 0.1862
180 -93.2 -136 10 145 0.6628 2.653 0.1656 0.00515 26.02 0.1656
200 -73.2 -100 10 145 0.5971 2.390 0.1492 0.00464 23.44 0.1492
220 -53.2 -63.7 10 145 0.5431 2.174 0.1357 0.00422 21.32 0.1357
240 -33.2 -27.7 10 145 0.4982 1.994 0.1245 0.00387 19.55 0.1245
260 -13.2 8.3 10 145 0.4602 1.842 0.1150 0.00357 18.06 0.1150
280 6.9 44.3 10 145 0.4275 1.711 0.1068 0.00332 16.78 0.1068
300 26.9 80.3 10 145 0.3990 1.597 0.09970 0.00310 15.66 0.09970
320 46.9 116 10 145 0.3743 1.498 0.09352 0.00291 14.69 0.09352
340 66.9 152 10 145 0.3523 1.410 0.08802 0.00274 13.83 0.08802
360 86.9 188 10 145 0.3328 1.332 0.08315 0.00258 13.06 0.08315
400 127 260 10 145 0.2998 1.200 0.07491 0.00233 11.77 0.07491
500 227 440 10 145 0.2399 0.9604 0.05996 0.00186 9.42 0.05996
600 327 620 10 145 0.2000 0.8007 0.04999 0.00155 7.85 0.04999
700 427 800 10 145 0.1715 0.6866 0.04286 0.00133 6.73 0.04286
800 527 980 10 145 0.1501 0.6009 0.03751 0.00117 5.89 0.03751
900 627 1160 10 145 0.1335 0.5342 0.03335 0.00104 5.24 0.03335
1000 727 1340 10 145 0.1201 0.4809 0.03002 0.00093 4.72 0.03002
Supercritical
phase
100 -173 -280 50 725 5.606 22.44 1.401 0.04354 220.0 1.401
350 76.9 170 50 725 1.658 6.636 0.4143 0.01288 65.08 0.4143
600 327 620 50 725 0.9920 3.971 0.2479 0.00770 38.94 0.2479
850 577 1070 50 725 0.7027 2.812 0.1756 0.00546 27.58 0.1756
1100 827 1520 50 725 0.5439 2.177 0.1359 0.00422 21.35 0.1359
1350 1077 1970 50 725 0.4437 1.776 0.1109 0.00345 17.42 0.1109
Supercritical
phase
20 -253 -424 100 1450 36.78 147 9.189 0.2856 1444 9.189
40 -233 -388 100 1450 22.82 91 5.702 0.1772 895.6 5.702
60 -213 -352 100 1450 16.33 65 4.080 0.1268 641.0 4.080
80 -193 -316 100 1450 12.76 51 3.189 0.09913 501.0 3.189
100 -173 -280 100 1450 10.51 42.1 2.625 0.08159 412.4 2.625
120 -153 -244 100 1450 8.94 35.8 2.233 0.06941 350.8 2.233
140 -133 -208 100 1450 7.780 31.1 1.944 0.06042 305.4 1.944
160 -113 -172 100 1450 6.891 27.6 1.722 0.05351 270.5 1.722
180 -93.2 -136 100 1450 6.183 24.8 1.545 0.04802 242.7 1.545
200 -73.2 -100 100 1450 5.611 22.5 1.402 0.04358 220.3 1.402
220 -53.2 -63.7 100 1450 5.134 20.6 1.283 0.03987 201.5 1.283
240 -33.2 -27.7 100 1450 4.732 18.9 1.182 0.03675 185.7 1.182
260 -13.2 8.3 100 1450 4.390 17.6 1.097 0.03409 172.3 1.097
280 6.9 44.3 100 1450 4.092 16.4 1.023 0.03178 160.6 1.023
300 26.9 80.3 100 1450 3.833 15.3 0.9576 0.02976 150.4 0.9576
320 46.9 116 100 1450 3.605 14.4 0.9008 0.02800 141.5 0.9008
340 66.9 152 100 1450 3.403 13.62 0.8503 0.02643 133.6 0.8503
360 86.9 188 100 1450 3.220 12.89 0.8047 0.02501 126.4 0.8047
400 127 260 100 1450 2.911 11.65 0.7273 0.02260 114.2 0.7273
500 227 440 100 1450 2.345 9.39 0.5860 0.01821 92.06 0.5860
600 327 620 100 1450 1.964 7.86 0.4907 0.01525 77.08 0.4907
700 427 800 100 1450 1.689 6.76 0.4220 0.01312 66.29 0.4220
800 527 980 100 1450 1.482 5.93 0.3702 0.01151 58.15 0.3702
900 627 1160 100 1450 1.319 5.28 0.3297 0.01025 51.79 0.3297
1000 727 1340 100 1450 1.189 4.76 0.2972 0.00924 46.68 0.2972
Supercritical
phase
100 -173 -280 500 7250 35.38 141.6 8.842 0.2748 1389 8.842
350 76.9 170 500 7250 14.39 57.6 3.595 0.1117 564.7 3.595
600 327 620 500 7250 9.06 36.3 2.264 0.07036 355.6 2.264
850 577 1070 500 7250 6.60 26.4 1.650 0.05130 259.3 1.650
1100 827 1520 500 7250 5.19 20.8 1.298 0.04033 203.8 1.298
1350 1077 1970 500 7250 4.28 17.1 1.069 0.03322 167.9 1.069
Density units conversion:
Density converter
Densities
Fluid Mechanics
Material Properties
Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Ethane Gas - Specific Heat vs. Temperature
Specific heat of Ethane Gas - C2H6 - for temperatures ranging 250 - 900 K.
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
