Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                      (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = m g / V
  = ρ g                        (2)
Tabulated values of hydrogen density at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Hydrogen Density Calculator
The calculator below can be used to estimate the density and specific weight of gaseous hydrogen at given temperature and atmospheric pressure (1 bara/14.5psia).
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
For calculation of density at higher pressure (up to 100 bara / 1450 psia), a good approximation is to multiply the density at 1 bara with the actual, higher pressure (in bara). If pressure is given in psia, you have to multiply the density at 14.5 psia with the actual higher pressure (in psia) and divide by 14.5.
Note! For pressure  between 20 and 100 bara, the error may be up to 7% by using this approximation (higher error, the higher pressure).
Example 1: Density of hydrogen at 5 bara and 24 °C.
Calculator gives the density at 24 °C and 1 bara: 0.0815 (kg/m3)
Density at 24°C and 5 bara : 0.0815 (kg/m3)* 5(bara)/1(bara) = 0.408 (kg/m3)
Example 2: Density of hydrogen at 725 psia and 125 °F.
Calculator gives the density at 125 °F and 14.5 psia: 0.00465 (lbm/ft3)
Density at 125°F and 725 psia : 0.00465 (lbm/ft3)* 725(psia)/14.5(psia) = 0.233 (lbm/ft3)
(this is 3% more than the below tabulated value of density at 125°F and 725 psia.)
See also other properties of Hydrogen at varying temperature and pressure: Specific heat (Heat capacity) and Thermal conductivity, and Thermophysical properties at standard conditions, as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water .
Density and specific weight of hydrogen at given temperatures and pressures:
For full table with Denity and Specific Weight - rotate the screen!
(K) (°C) (°F) (MPa) (bara) (psia) (mol/dm3) (g/l),
(kg/m3)
(lbm/ft3) (sl/ft3 ×10-3) (N/m3) (lbf/ft3)
Liquid at
equilibrium
pressure
13.96 -259.2 -434.5 0.00770 0.0770 1.12 38.15 76.91 4.801 149.2 754.2 4.801
14 -259 -434 0.00789 0.0789 1.14 38.13 76.87 4.799 149.1 753.8 4.799
16 -257 -431 0.0215 0.215 3.12 37.26 75.12 4.689 145.8 736.7 4.689
18 -255 -427 0.0481 0.481 6.97 36.32 73.22 4.571 142.1 718.1 4.571
20 -253 -424 0.0932 0.932 13.5 35.27 71.11 4.439 138.0 697.4 4.439
22 -251 -420 0.163 1.63 23.7 34.09 68.73 4.291 133.4 674.0 4.291
24 -249 -416 0.264 2.64 38.3 32.74 66.00 4.120 128.1 647.2 4.120
26 -247 -413 0.403 4.03 58.4 31.15 62.80 3.921 121.9 615.9 3.921
28 -245 -409 0.585 5.85 84.9 29.23 58.92 3.678 114.3 577.8 3.678
30 -243 -406 0.850 8.50 123 26.71 53.84 3.361 104.5 528.0 3.361
32 -241 -402 1.12 11.2 162 22.64 45.64 2.849 88.55 447.5 2.849
33.19 -240.0 -399.9 1.33 13.3 193 14.94 30.12 1.880 58.44 295.4 1.880
Gas at
equilibrium
pressure
13.96 -259.2 -434.5 0.00770 0.0770 1.12 0.06754 0.1362 8.50E-03 0.2642 1.335 8.50E-03
14 -259 -434 0.00789 0.0789 1.14 0.06902 0.1391 8.69E-03 0.2700 1.365 8.69E-03
16 -257 -431 0.0215 0.215 3.12 0.1676 0.3380 0.02110 0.6558 3.314 0.02110
18 -255 -427 0.0481 0.481 6.97 0.3413 0.6880 0.04295 1.335 6.747 0.04295
20 -253 -424 0.0932 0.932 13.5 0.6165 1.243 0.07759 2.412 12.19 0.07759
22 -251 -420 0.163 1.63 23.7 1.025 2.067 0.1290 4.010 20.27 0.1290
24 -249 -416 0.264 2.64 38.3 1.609 3.244 0.2025 6.294 31.81 0.2025
26 -247 -413 0.403 4.03 58.4 2.431 4.900 0.3059 9.508 48.06 0.3059
28 -245 -409 0.585 5.85 84.9 3.600 7.258 0.4531 14.08 71.18 0.4531
30 -243 -406 0.850 8.50 123 5.364 10.81 0.6751 20.98 106.1 0.6751
32 -241 -402 1.12 11.2 162 8.682 17.50 1.093 33.96 171.7 1.093
58.44
295.4 1.880
Liquid 20 -253 -424 0.1 1 14.5 35.29 71.14 4.441 138.0 698 4.44
20.23 -252.9 -423.3 0.1 1 14.5 35.16 70.88 4.425 137.5 695 4.42
Gas
20.23 -252.9 -423.3 0.1 1 14.5 0.6563 1.323 0.08259 2.567 13.0 0.0826
40 -233 -388 0.1 1 14.5 0.3054 0.6157 0.03844 1.195 6.04 0.0384
60 -213 -352 0.1 1 14.5 0.2013 0.4059 0.02534 0.7876 3.98 0.0253
80 -193 -316 0.1 1 14.5 0.1505 0.3035 0.01895 0.5889 2.98 0.0189
100 -173 -280 0.1 1 14.5 0.1203 0.2425 0.01514 0.4705 2.38 0.0151
120 -153 -244 0.1 1 14.5 0.1002 0.2020 0.01261 0.3919 1.98 0.0126
140 -133 -208 0.1 1 14.5 0.08586 0.1731 0.01081 0.3359 1.70 0.0108
160 -113 -172 0.1 1 14.5 0.07510 0.1514 0.009452 0.2938 1.48 0.00945
180 -93.2 -136 0.1 1 14.5 0.06677 0.1346 0.008403 0.2612 1.32 0.00840
200 -73.2 -99.7 0.1 1 14.5 0.06007 0.1211 0.007560 0.2350 1.19 0.00756
220 -53.2 -63.7 0.1 1 14.5 0.05461 0.1101 0.006873 0.2136 1.08 0.00687
240 -33.2 -27.7 0.1 1 14.5 0.05010 0.1010 0.006305 0.1960 0.990 0.00631
260 -13.2 8.3 0.1 1 14.5 0.04623 0.09319 0.005818 0.1808 0.914 0.00582
280 6.9 44.3 0.1 1 14.5 0.04293 0.08654 0.005403 0.1679 0.849 0.00540
300 26.9 80.3 0.1 1 14.5 0.04006 0.08077 0.005042 0.1567 0.792 0.00504
320 46.9 116 0.1 1 14.5 0.03756 0.07572 0.004727 0.1469 0.743 0.00473
340 66.9 152 0.1 1 14.5 0.03535 0.07127 0.004449 0.1383 0.699 0.00445
360 86.9 188 0.1 1 14.5 0.03339 0.06731 0.004202 0.1306 0.660 0.00420
400 127 260 0.1 1 14.5 0.03005 0.06058 0.003782 0.1175 0.594 0.00378
500 227 440 0.1 1 14.5 0.02404 0.04847 0.003026 0.09405 0.475 0.00303
600 327 620 0.1 1 14.5 0.02004 0.04040 0.002522 0.07839 0.396 0.00252
700 427 800 0.1 1 14.5 0.01718 0.03463 0.002162 0.06719 0.340 0.00216
800 527 980 0.1 1 14.5 0.01503 0.03030 0.001892 0.05879 0.297 0.00189
900 627 1160 0.1 1 14.5 0.01336 0.02693 0.001681 0.05225 0.264 0.00168
1000 727 1340 0.1 1 14.5 0.01202 0.02424 0.001513 0.04703 0.238 0.00151
Liquid 20 -253 -424 1 10 145 35.86 72.29 4.513 140.3 709 4.51
31.24 -241.9 -403.4 1 10 145 24.63 49.65 3.100 96.34 487 3.10
Gas
31.24 -241.9 -403.4 1 10 145 7.098 14.31 0.8933 27.77 140 0.893
40 -233 -388 1 10 145 3.606 7.270 0.4539 14.11 71.3 0.454
60 -213 -352 1 10 145 2.097 4.228 0.2639 8.204 41.5 0.264
80 -193 -316 1 10 145 1.524 3.072 0.1918 5.961 30.1 0.192
100 -173 -280 1 10 145 1.205 2.429 0.1516 4.713 23.8 0.152
120 -153 -244 1 10 145 0.9995 2.015 0.1258 3.910 19.8 0.126
140 -133 -208 1 10 145 0.8547 1.723 0.1076 3.343 16.9 0.108
160 -113 -172 1 10 145 0.7470 1.506 0.09402 2.922 14.8 0.0940
180 -93.2 -136 1 10 145 0.6637 1.338 0.08353 2.596 13.1 0.0835
200 -73.2 -99.7 1 10 145 0.5972 1.204 0.07516 2.336 11.8 0.0752
220 -53.2 -63.7 1 10 145 0.5432 1.095 0.06836 2.125 10.7 0.0684
240 -33.2 -27.7 1 10 145 0.4980 1.004 0.06268 1.948 9.85 0.0627
260 -13.2 8.3 1 10 145 0.4597 0.9267 0.05785 1.798 9.09 0.0579
280 6.9 44.3 1 10 145 0.4269 0.8607 0.05373 1.670 8.44 0.0537
300 26.9 80.3 1 10 145 0.3986 0.8035 0.05016 1.559 7.88 0.0502
320 46.9 116 1 10 145 0.3737 0.7534 0.04703 1.462 7.39 0.0470
340 66.9 152 1 10 145 0.3518 0.7093 0.04428 1.376 6.96 0.0443
360 86.9 188 1 10 145 0.3323 0.6700 0.04183 1.300 6.57 0.0418
400 127 260 1 10 145 0.2993 0.6033 0.03766 1.171 5.92 0.0377
500 227 440 1 10 145 0.2396 0.4830 0.03015 0.9372 4.74 0.0302
600 327 620 1 10 145 0.1998 0.4027 0.02514 0.7814 3.95 0.0251
700 427 800 1 10 145 0.1713 0.3454 0.02156 0.6702 3.39 0.0216
800 527 980 1 10 145 0.1500 0.3023 0.01887 0.5866 2.96 0.0189
900 627 1160 1 10 145 0.1333 0.2688 0.01678 0.5216 2.64 0.0168
1000 727 1340 1 10 145 0.1200 0.2420 0.01511 0.4696 2.37 0.0151
Liquid 25 -248 -415 5 50 725 35.66 71.89 4.488 139.5 705 4.49
Supercritical
phase
100 -173 -280 5 50 725 5.968 12.03 0.7511 23.35 118 5.98
175 -98.2 -145 5 50 725 3.313 6.679 0.4170 12.96 65.5 0.417
250 -23.2 -9.7 5 50 725 2.327 4.691 0.2928 9.102 46.0 0.293
325 51.9 125 5 50 725 1.799 3.627 0.2264 7.037 35.6 0.226
400 127 260 5 50 725 1.468 2.959 0.1848 5.742 29.0 0.185
Liquid 25 -248 -415 10 100 1450 37.93 76.47 4.774 148.4 750 4.77
Supercritical
phase
100 -173 -280 10 100 1450 11.42 23.02 1.437 44.66 226 1.44
175 -98.2 -145 10 100 1450 6.370 12.84 0.8017 24.92 126 0.802
250 -23.2 -9.7 10 100 1450 4.503 9.078 0.5667 17.61 89.0 0.567
325 51.9 125 10 100 1450 3.501 7.057 0.4406 13.69 69.2 0.441
400 127 260 10 100 1450 2.869 5.783 0.3610 11.22 56.7 0.361
Density units conversion:
Density converter
Densities
Fluid Mechanics
Material Properties
Thermodynamics
Air Properties: Temperature, Pressure & Density Data
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Hydrogen - Specific Heat
Specific heat of Hydrogen Gas - H2 - at temperatures ranging 175 - 6000 K.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
