Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                                (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = (m g) / V
   = ρ g                                     (2)
Tabulated values of carbon dioxide density at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Carbon Dioxide Density Calculator
The calculator below can be used to estimate the density and specific weight of gaseous carbon dioxide at given temperature and pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
Choose the actual pressure:
See also other properties of Carbon dioxide at varying temperature and pressure: Dynamic and kinematic viscosity, Prandtl number, Specific heat (Heat capacity) and Thermal conductivity, and Thermophysical properties at standard conditions, as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water .
Carbon dioxide density temperature C
Carbon dioxide density temperature F
Carbon dioxide density temperature pressure C
Density and specific weight of carbon dioxide at given temperatures and pressures:
(K) (°C) (°F) (MPa) (bara) (psia) (mol/dm3) (g/l)
(kg/m3)
(lbm/ft3) (sl/ft3 ×10-3) (N/m3) (lbf/ft3)
Gas 220 -53.2 -63.7 0.1 1 14.5 0.05542 2.439 0.1523 4.732 23.9 0.152
240 -33.2 -27.7 0.1 1 14.5 0.05063 2.228 0.1391 4.323 21.8 0.139
250 -23.2 -9.7 0.1 1 14.5 0.04854 2.136 0.1334 4.145 21.0 0.133
260 -13.2 8.3 0.1 1 14.5 0.04663 2.052 0.1281 3.982 20.1 0.128
280 6.9 44.3 0.1 1 14.5 0.04322 1.902 0.1187 3.690 18.7 0.119
300 26.9 80.3 0.1 1 14.5 0.04029 1.773 0.1107 3.440 17.4 0.111
320 47 116 0.1 1 14.5 0.03774 1.661 0.1037 3.223 16.3 0.104
340 67 152 0.1 1 14.5 0.03549 1.562 0.09751 3.031 15.3 0.0975
360 87 188 0.1 1 14.5 0.03349 1.474 0.09202 2.860 14.5 0.0920
400 127 260 0.1 1 14.5 0.03013 1.326 0.08278 2.573 13.0 0.0828
450 177 350 0.1 1 14.5 0.02658 1.170 0.07303 2.270 11.5 0.0730
500 227 440 0.1 1 14.5 0.02406 1.059 0.06611 2.055 10.4 0.0661
600 327 620 0.1 1 14.5 0.02005 0.8824 0.05509 1.712 8.65 0.0551
650 377 710 0.1 1 14.5 0.01851 0.8144 0.05084 1.580 7.99 0.0508
850 577 1070 0.1 1 14.5 0.01415 0.6226 0.03887 1.208 6.11 0.0389
1050 777 1430 0.1 1 14.5 0.01145 0.5040 0.03146 0.978 4.94 0.0315
Gas 233.03 -40.1 -40.2 1 10 145 0.5910 26.01 1.624 50.47 255 1.62
240 -33.2 -27.7 1 10 145 0.5649 24.86 1.552 48.24 244 1.55
250 -23.2 -9.7 1 10 145 0.5325 23.44 1.463 45.47 230 1.46
260 -13.2 8.3 1 10 145 0.5047 22.21 1.387 43.09 218 1.39
280 6.9 44.3 1 10 145 0.4590 20.20 1.261 39.19 198 1.26
300 26.9 80.3 1 10 145 0.4222 18.58 1.160 36.05 182 1.16
320 47 116 1 10 145 0.3915 17.23 1.076 33.43 169 1.08
340 67 152 1 10 145 0.3656 16.09 1.004 31.22 158 1.00
360 87 188 1 10 145 0.3433 15.11 0.9433 29.32 148 0.943
400 127 260 1 10 145 0.3063 13.48 0.8415 26.16 132 0.842
450 177 350 1 10 145 0.2704 11.90 0.7428 23.09 117 0.743
500 227 440 1 10 145 0.2422 10.66 0.6655 20.68 105 0.665
600 327 620 1 10 145 0.2010 8.845 0.5522 17.16 86.7 0.552
650 377 710 1 10 145 0.1853 8.154 0.5090 15.82 80.0 0.509
850 577 1070 1 10 145 0.1413 6.219 0.3882 12.07 61.0 0.388
1050 777 1430 1 10 145 0.1143 5.030 0.3140 9.760 49.3 0.314
Liquid 250 -23.2 -9.7 5 50 725 24.06 1059 66.10 2055 10384 66.1
287.43 14.3 57.7 5 50 725 18.80 827.3 51.65 1605 8113 51.6
Gas 287.43 14.3 57.7 5 50 725 3.560 156.67 9.781 304.0 1536 9.78
450 177 350 5 50 725 1.416 62.30 3.889 120.9 611 3.89
650 377 710 5 50 725 0.9298 40.92 2.555 79.40 401 2.55
850 577 1070 5 50 725 0.7024 30.91 1.930 59.98 303 1.93
1050 777 1430 5 50 725 0.5666 24.93 1.557 48.38 245 1.56
Liquid 250 -23.2 -9.7 10 100 1450 24.46 1076 67.20 2089 10556 67.2
Supercritical phase 450 177 350 10 100 1450 2.991 131.6 8.218 255.4 1291 8.22
650 377 710 10 100 1450 1.863 82.00 5.119 159.1 804.1 5.12
850 577 1070 10 100 1450 1.393 61.31 3.827 119.0 601 3.83
1050 777 1430 10 100 1450 1.121 49.31 3.078 95.68 484 3.08
Supercritical phase 250 -23.2 -9.7 100 1000 14504 28.08 1236 77.13 2397 12117 77.1
450 177 350 100 1000 14504 19.25 847.0 52.88 1643 8306 52.9
650 377 710 100 1000 14504 13.68 601.9 37.58 1168 5903 37.6
850 577 1070 100 1000 14504 10.64 468.1 29.22 908.2 4590 29.2
1050 777 1430 100 1000 14504 8.793 387.0 24.16 750.8 3795 24.2
Density units conversion:
Density converter
