Density is the ratio of the mass to the volume of a substance:
ρ = m / V                                          (1)
ρ = density, units typically (kg/m3) or (lb/ft3)
Specific weight is the ratio of the weight to the volume of a substance:
γ   = m g / V
    = ρ g                                     (2)
γ = specific weight, units typically (N/m3) or (lbf/ft3)
m = mass, units typically (g) or (lb)
g = acceleration due to gravity, units typically (m/s2) and value on Earth usually given as 9.80665 m/s2or 32.17405 ft/s2
V = volume, units typically (cm3) or (ft3)
ρ = density, units typically (g/cm3) or (lb/ft3)
Tabulated values and density units conversion are given below the figures . At the bottom of the page there are some examples of calculations using hot and cold air.
See also Air Composition and molecular weight, Density at varying pressure , Diffusion Coefficients for Gases in Air, Dynamic (absolute) and kinematic viscosity, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Conductivity, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air thermophysical properties, for other properties of air .
For other substances, see Density and specific weight o acetone, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water, as well as Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Online Air Density Calculator
The calculator below can be used to calculate the air density and specific weight at given temperatures and atmospheric pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ft3.
Note! Temperature must be within the ranges -100 - 1600 °C, -140 - 2900 °F, 175 - 1900 K and 315 - 3400 °R to get valid values.
Air density and specific weight at atmospheric pressure:
Air density 1atm temp C
Air density 1atm temp F
Air density at ambient temperature and pressure:
Air density ambient pressures temp C
Air density ambient pressures temp F
Air density at varying pressure and temperature:
Air density pressure temp C
Air density pressure temp F
Air density at gas-liquid equilibrium pressure:
air density equlibrium pressure gas liquid C
Air thermal expansion coefficient at atmospheric pressure:
Air thermal expansion 1atm temp C
Air thermal expansion 1atm temp F
Density, specific weight and thermal expansion coefficient of air at 1 atmosphere pressure, at temperatures given as °F:
For full table specific weight and thermal expansion coefficient - rotate the screen!
Temperature Density Specific weight Thermal expansion coefficient
(°F) (lbm/ft3) (slugs/ft3×10-3) (lbm/gal(US liq)) (kg/m3) (lbf/ft3) (N/m3) (×10-3 °F-1)
-100 0.1104 3.431 0.01476 1.768 0.1104 17.34 2.83
-50 0.0968 3.010 0.01295 1.551 0.0968 15.21 2.48
-20 0.0902 2.803 0.01206 1.445 0.0902 14.17 2.30
0 0.0862 2.681 0.01153 1.382 0.0862 13.55 2.20
10 0.0844 2.624 0.01128 1.352 0.0844 13.26 2.15
20 0.0826 2.569 0.01105 1.324 0.0826 12.98 2.10
30 0.0810 2.516 0.01082 1.297 0.0810 12.72 2.06
40 0.0793 2.466 0.01061 1.271 0.0793 12.46 2.02
50 0.0778 2.418 0.01040 1.246 0.0778 12.22 1.98
60 0.0763 2.372 0.01020 1.222 0.0763 11.99 1.94
70 0.0749 2.327 0.01001 1.199 0.0749 11.76 1.90
80 0.0735 2.284 0.00982 1.177 0.0735 11.55 1.87
100 0.0709 2.203 0.00948 1.135 0.0709 11.14 1.80
120 0.0685 2.128 0.00915 1.097 0.0685 10.75 1.74
140 0.0662 2.057 0.00885 1.060 0.0662 10.40 1.68
160 0.0641 1.991 0.00856 1.026 0.0641 10.06 1.63
180 0.0621 1.929 0.00830 0.994 0.0621 9.75 1.58
200 0.0602 1.870 0.00804 0.964 0.060 9.45 1.53
250 0.0559 1.738 0.00747 0.896 0.0559 8.78 1.41
300 0.0522 1.622 0.00698 0.836 0.0522 8.20 1.30
350 0.0489 1.521 0.00654 0.784 0.0489 7.69 1.23
400 0.0461 1.432 0.00616 0.738 0.0461 7.24 1.16
450 0.0436 1.354 0.00582 0.698 0.0436 6.84 1.10
500 0.0410 1.274 0.00548 0.656 0.0410 6.43 1.05
600 0.0371 1.152 0.00496 0.599 0.0371 5.82 0.96
700 0.0340 1.057 0.00455 0.545 0.0340 5.35 0.88
800 0.0315 0.978 0.00421 0.5042 0.0315 4.94 0.81
1000 0.0272 0.845 0.00363 0.4354 0.0272 4.27 0.70
1200 0.0239 0.743 0.00319 0.3827 0.0239 3.75 0.61
1400 0.0213 0.663 0.00285 0.3416 0.0213 3.35 0.54
1600 0.0193 0.599 0.00257 0.3085 0.0193 3.03 0.49
1800 0.0176 0.546 0.00235 0.2813 0.0176 2.76 0.45
2000 0.0161 0.501 0.00216 0.2583 0.0161 2.53 0.42
Density and specific weight of air at 1 atmosphere pressure, at temperatures given as °C:
(°C) (kg/m3) (lbm/ft3) (sl/ft3 ×10-3) (lbm/gal(US liq)) (N/m3) (lbf/ft3) (×10-3 K-1)
-75 1.783 0.1113 3.460 0.01488 17.49 0.11131 5.14
-50 1.582 0.0988 3.070 0.01320 15.52 0.09878 4.55
-25 1.422 0.0888 2.759 0.01187 13.94 0.08877 4.08
-15 1.367 0.0853 2.652 0.01141 13.40 0.08532 3.92
-10 1.341 0.0837 2.601 0.01119 13.15 0.08370 3.84
-5 1.316 0.0821 2.553 0.01098 12.90 0.08214 3.76
0 1.292 0.0806 2.506 0.01078 12.67 0.08063 3.69
5 1.268 0.0792 2.461 0.01059 12.44 0.07919 3.62
10 1.246 0.0778 2.418 0.01040 12.22 0.07780 3.56
15 1.225 0.0765 2.376 0.01022 12.01 0.07645 3.50
20 1.204 0.0752 2.336 0.01005 11.81 0.07516 3.43
25 1.184 0.0739 2.297 0.00988 11.61 0.07390 3.38
30 1.164 0.0727 2.259 0.00972 11.42 0.07269 3.32
40 1.127 0.0704 2.188 0.00941 11.06 0.07039 3.21
50 1.093 0.0682 2.120 0.00912 10.72 0.06822 3.12
60 1.060 0.0662 2.057 0.00885 10.40 0.06619 3.02
80 1.000 0.0625 1.941 0.00835 9.81 0.06245 2.85
100 0.9467 0.0591 1.837 0.00790 9.28 0.05910 2.70
125 0.8868 0.0554 1.721 0.00740 8.70 0.05536 2.51
150 0.8338 0.0521 1.618 0.00696 8.18 0.05206 2.33
175 0.7868 0.0491 1.527 0.00657 7.72 0.04912 2.22
200 0.7451 0.0465 1.446 0.00622 7.31 0.04651 2.10
225 0.7078 0.0442 1.373 0.00591 6.94 0.04419 2.01
300 0.6168 0.0385 1.197 0.00515 6.05 0.03850 1.76
400 0.5238 0.0327 1.016 0.00437 5.14 0.03270 1.52
500 0.4567 0.0285 0.886 0.00381 4.48 0.02851 1.32
600 0.4043 0.0252 0.784 0.00337 3.96 0.02524 1.16
700 0.3626 0.0226 0.704 0.00303 3.56 0.02264 1.03
800 0.3289 0.0205 0.638 0.00274 3.23 0.02053 0.94
900 0.3009 0.0188 0.584 0.00251 2.95 0.01879 0.86
1000 0.2773 0.0173 0.538 0.00231 2.72 0.01731 0.80
1100 0.2571 0.0160 0.499 0.00215 2.52 0.01605 0.75
Density units conversion:
Density converter
Example - Mass of Air at Temperature 100 oC
From the table above - the density of air is 0.946 kg/m3 at 100 oC. The mass of 10 m3 air can be calculated as
m = V ρ
= (10 m3) (0.946 kg/m3)
= 9.46 (kg)
m = mass (kg)
V = volume (m3)
ρ = density (kg/m3)
Example - Mass of Air at Temperature 20 oC
From the table above - the density of air is 1.205 kg/m3 at 20 oC. The mass of 10 m3 air can be calculated as
m = (10 m3) (1.205 kg/m3
= 12.05 (kg)
Example - Lifting Force of a Hot Air Balloon
An air balloon with volume 10 m3 is heated to 100 oC. The temperature of the surrounding air is 20 oC. The change in gravity force (weight) of the air volume is the potential lifting force of the balloon. The lifting force can be calculated as
Fl = dm ag
= V dρ ag
= (10 m3) (1.205 - 0.946) (kg/m3) (9.81 m/s2
= 25.4 (N)
Fl = lifting force - change in gravity force (weight)  (N)
ag = acceleration of gravity (9.81 m/s2)
dm = V dρ = change of mass in the balloon (kg)
dρ = change in density due to temperature difference (kg/m3)
