Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                           (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = (m g) / V
   = ρ g                           (2)
Tabulated values of acetone density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Acetone phase diagram
Online Acetone Density Calculator
The calculator below can be used to estimate the density and specific weight of liquid acetone at given temperature at saturation pressure.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
See also acetone : Thermophysical properties at standard conditions,  as well as density and specific weight at varying temperature and pressure of air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water . Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Density and specific weight of acetone along the boiling and condensation curve, SI and Imperial units:
Acetone liquid density equilibrium C
Acetone liquid density equilibrium F
Density of liquid acetone at varying temperature (°C) and given pressures:
Acetone liquid density pressure C
The density of liquid acetone is nearly the same for all pressures up to 100 bara for temperatures below 200°C/390°F, and the density of the liquid at equilibrium pressure (as used in the calculator above) can be used for most practical purposes.
Density of acetone vapor (singel phase) at varying temperature and given pressures, SI and Imperial units:
Acetone gas density pressure C
Acetone gas density pressure F
Density and specific weight of acetone at given temperatures and pressures:
(K) (°C) (°F) (MPa) (bara) (psia) (mol/dm3) (g/l),
(kg/m3)
(lbm/ft3) (sl/ft3) (N/m3) (lbf/ft3)
Liquid at
equilibrium
178.5 -94.7 -138.4 2.326E-06 0.0000233 0.000337 15.72 913.2 57.01 1.772 8955 57.0
210 -63.2 -81.7 9.66E-05 0.000966 0.0140 15.14 879.4 54.90 1.706 8624 54.9
240 -33.2 -27.7 0.00120 0.0120 0.174 14.59 847.5 52.91 1.645 8312 52.9
270 -3.1 26.3 0.00785 0.0785 1.139 14.04 815.5 50.91 1.582 7997 50.9
300 26.9 80.3 0.03326 0.3326 4.824 13.47 782.6 48.85 1.518 7674 48.9
330 56.9 134 0.1040 1.040 15.09 12.88 748.1 46.70 1.451 7336 46.7
360 86.9 188 0.2619 2.619 37.98 12.24 711.1 44.39 1.380 6973 44.4
390 117 242 0.5624 5.624 81.56 11.55 670.5 41.86 1.301 6576 41.9
420 147 296 1.073 10.73 155.7 10.75 624.5 38.99 1.212 6124 39.0
450 177 350 1.876 18.76 272.1 9.804 569.4 35.55 1.105 5584 35.5
480 207 404 3.073 30.73 445.6 8.542 496.1 30.97 0.9626 4865 31.0
508.1 235.0 454.9 4.692 46.92 680.6 4.700 273.0 17.04 0.5297 2677 17.0
Gas at
equilibrium
178.5 -94.7 -138.4 2.33E-06 0.0000233 0.000337 1.57E-06 0.00 5.68E-06 1.77E-07 0.0009 5.68E-06
210 -63.2 -81.7 9.66E-05 0.000966 0.014 5.54E-05 0.00 0.00020 6.24E-06 0.0315 2.01E-04
240 -33.2 -27.7 0.00120 0.0120 0.174 0.000604 0.04 0.00219 6.80E-05 0.344 0.0022
270 -3.1 26.3 0.00785 0.0785 1.139 0.003537 0.21 0.01282 0.000399 2.01 0.0128
300 26.9 80.3 0.03326 0.3326 4.824 0.0137 0.80 0.04967 0.00154 7.80 0.0497
330 56.9 134 0.1040 1.040 15.09 0.0400 2.325 0.1452 0.00451 22.8 0.145
360 86.9 188 0.2619 2.619 37.98 0.0964 5.597 0.3494 0.0109 54.9 0.349
390 117 242 0.5624 5.624 81.56 0.2033 11.81 0.7371 0.0229 116 0.737
420 147 296 1.073 10.73 155.7 0.3942 22.89 1.429 0.0444 225 1.43
450 177 350 1.876 18.76 272.1 0.7347 42.67 2.664 0.0828 418 2.66
480 207 404 3.073 30.73 445.6 1.405 81.61 5.095 0.1583 800 5.09
508.1 235 455 4.692 46.92 680.6 4.700 273.0 17.04 0.5297 2677 17.0
Liquid 200 -73.2 -99.7 0.1 1 14.5 15.33 890.1 55.56 1.727 8729 55.6
250 -23.2 -9.7 0.1 1 14.5 14.41 837.0 52.25 1.624 8208 52.3
300 26.9 80.3 0.1 1 14.5 13.48 782.6 48.86 1.519 7675 48.9
328.8 55.7 132.2 0.1 1 14.5 12.90 749.4 46.78 1.454 7349 46.8
Gas 328.8 55.7 132 0.1 1 14.5 0.0386 2.240 0.1398 0.00435 22.0 0.140
350 76.9 170 0.1 1 14.5 0.0357 2.074 0.1295 0.00402 20.3 0.129
400 127 260 0.1 1 14.5 0.0307 1.784 0.1113 0.00346 17.5 0.111
450 177 350 0.1 1 14.5 0.0271 1.573 0.0982 0.00305 15.4 0.0982
500 227 440 0.1 1 14.5 0.0243 1.410 0.0880 0.00274 13.8 0.0880
550 277 530 0.1 1 14.5 0.0220 1.278 0.0798 0.00248 12.5 0.0798
Liquid 200 -73.2 -99.7 1 10 145 15.33 890.5 55.59 1.728 8733 55.6
250 -23.2 -9.7 1 10 145 14.42 837.7 52.29 1.625 8215 52.3
300 26.9 80.3 1 10 145 13.49 783.5 48.92 1.520 7684 48.9
350 76.9 170 1 10 145 12.48 725.0 45.26 1.407 7110 45.3
400 127 260 1 10 145 11.31 656.8 41.00 1.274 6441 41.0
416.5 143 290 1 10 145 10.85 630.3 39.35 1.223 6181 39.3
Gas 416.5 143 290 1 10 145 0.3658 21.25 1.326 0.0412 208.4 1.33
450 177 350 1 10 145 0.3125 18.15 1.133 0.0352 178.0 1.13
500 227 440 1 10 145 0.2654 15.41 0.9622 0.0299 151.1 0.962
550 277 530 1 10 145 0.2339 13.59 0.8481 0.0264 133.2 0.848
Liquid 200 -73.2 -99.7 5 50 725 15.37 892.5 55.72 1.732 8752 55.7
250 -23.2 -9.7 5 50 725 14.47 840.5 52.47 1.631 8242 52.5
300 26.9 80.3 5 50 725 13.56 787.6 49.17 1.528 7723 49.2
350 76.9 170 5 50 725 12.59 731.1 45.64 1.419 7170 45.6
400 127 260 5 50 725 11.49 667.3 41.66 1.295 6544 41.7
450 177 350 5 50 725 10.12 587.9 36.70 1.141 5766 36.7
500 227 440 5 50 725 7.814 453.8 28.33 0.8806 4450 28.3
supercritical
phase
550 277 530 5 50 725 1.734 100.7 6.289 0.1955 988 6.29
Liquid 200 -73.2 -99.7 10 100 1450 15.41 895.0 55.87 1.737 8777 55.9
250 -23.2 -9.7 10 100 1450 14.53 843.8 52.67 1.637 8275 52.7
300 26.9 80.3 10 100 1450 13.64 792.3 49.46 1.537 7769 49.5
350 76.9 170 10 100 1450 12.71 738.1 46.08 1.432 7239 46.1
400 127 260 10 100 1450 11.68 678.5 42.36 1.317 6654 42.4
450 177 350 10 100 1450 10.49 609.3 38.04 1.182 5975 38.0
500 227 440 10 100 1450 8.9733 521.2 32.53 1.011 5111 32.5
supercritical
phase
550 277 530 10 100 1450 6.66 386.8 24.15 0.7505 3793 24.1
supercritical
phase
250 -23.2 -9.7 100 1000 14504 15.32 889.8 55.55 1.726 8726 55.5
300 26.9 80.3 100 1000 14504 14.66 851.3 53.14 1.652 8348 53.1
350 76.9 170 100 1000 14504 14.02 814.4 50.84 1.580 7987 50.8
400 127 260 100 1000 14504 13.41 778.8 48.62 1.511 7637 48.6
450 177 350 100 1000 14504 12.81 744.2 46.46 1.444 7298 46.5
500 227 440 100 1000 14504 12.23 710.5 44.36 1.379 6968 44.4
550 277 530 100 1000 14504 11.67 678.0 42.33 1.316 6649 42.3
supercritical
phase
450 177 350 500 5000 72519 15.62 907.0 56.62 1.760 8894 56.6
500 227 440 500 5000 72519 15.31 889.0 55.50 1.725 8718 55.5
550 277 530 500 5000 72519 15.01 871.9 54.43 1.692 8550 54.4
Density units conversion:
Density converter
