Wood Hardness
For wood hardness is a measure of resistance to dent and wear.
The Janka test measures the force (N, lbf) required to embed an 11.28 mm steel ball into the wood half the ball's diameter. Larger force - harder wood.
The Janka Hardness Values and Hardness Grades for some common Wood Species
Wood | Janka Hardness (N) | Hardness Grades |
Brazilian Ebony | 16420 | Exceedingly hard |
Ipe | 16390 | |
Cumaru | 15470 | |
Ebony | 14300 | Extremely hard |
Golden Teak | 10400 | |
Merbau | 8560 | Very hard |
Hickory | 8100 | |
Rosewood | 7900 | Hard |
White Oak | 6000 | |
Ash | 5900 | Rather hard |
Birch | 5600 | |
Teak | 5140 | |
English Oak | 5000 | Firm |
Burmese Teak | 4600 | |
Black Walnut | 4500 | |
Cherry | 4200 | |
Mahogany | 3600 | |
Douglas Fir | 2900 | Soft |
Alder | 2600 | |
Chestnut | 2400 | |
Poplar | 2400 | |
Hemlock | 2200 | |
White Pine | 1900 | Very soft |
Balsa | 310 |
- 1 N = 0.2248 lbf
Brinell Hardness Number - BHN
The Brinell hardness test of metals and alloys.
Density of Wood Species: Data & Material Guide
Grit Size vs. Surface Roughness
Comparing sandpaper grit size and surface roughness.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood and Softwoods - Recommended Drill Bit Speeds
Hardwood and softwood drill speed chart.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Mineral Hardness - Mohs Scale
The Mohs qualitative ordinal scale characterizes the scratch resistance of various minerals.
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
Tree Species - Water Demand
Trees species and relative water demand.
Urban Tree Heights
Height of trees commonly used in towns and urban areas.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood Headers - Max. Supported Weight
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
