Concrete Slabs - Required Thickness
  • Driveways : 6 - 8 inches ( 0.15 - 0.2 m)
  • Side walks, barn and granny floors : 5 - 6 inches (0.125 - 0.15 m)
  • Porches, Home garage floors : 4 - 5 inches (0.1 - 0.125 m)
  • Farm building floors, Home basement floors : 4 inches (0.1 m)
Miscellaneous
Building Foundations - Loads
Typical loads on building foundations.
Concrete - Calculating Cubic Volume
Calculating the concrete volume required for an operation.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Concrete Walls - Volume
Estimate concrete wall volume.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Rebar - Metric Reinforcing Bar
Reinforcing bar - European metric dimensions.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
Walls - No. of Studs
Calculate required number of studs in a wall.
