Rebar - Metric Reinforcing Bar
Rebars - Metric Reinforcing Bars
Bar NumberMass
(kg/m)
Nominal Diameter
(mm)
Cross Sectional Area
(mm2)
10M 0.785 11.3 100
15M 1.570 16.0 200
20M 2.355 19.5 300
25M 3.925 25.2 500
30M 5.495 29.9 700
35M 7.850 35.7 1000
45M 11.775 43.7 1500
55M 19.625 56.4 2500
Miscellaneous
Concrete Columns
Estimate concrete volume required for concrete columns.
Concrete Footings - Volume
Estimate required concrete footing volume.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Slabs - Required Thickness
Required thickness of concrete slabs.
Concrete Slabs - Volume Estimates
Estimate required concrete volume per sq. ft.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Weight of round bars.
Rebar - U.S. Imperial Reinforcing Bar
U.S. imperial dimensions of rebar
Rebars - Weights
Weights of rebar rods - size ranging 1/4.
Steel Wool - Grades
Steel wool grades vs. fiber thickness.
