PVDF - PolyVinylidene Fluoride Pipes - Supports
Maximum support spacing for PVDF - PolyVinylidene Fluoride - pipes depends on the operating temperature. Maximum spacing between supports at different temperatures can be found in the tables below:
PVDF Pipe - Schedule 40
PVDF -  PolyVinylidene Fluoride Pipes Schedule 40 - Supports
NPS
(inches)
Maximum Support Spacing (feet)
Operating Temperature (oF)
801001401)
1/2 3 1/2 3 1/2 2
3/4 4 3 1/2 2 1/2
1 4 4 2 1/2
1 1/2 4 1/2 4 1/2 2 1/2
2 4 1/2 4 1/2 2 1/2
PVDF Pipe - Schedule 80
PVDF -  PolyVinylidene Fluoride Pipes Schedule 80 - Supports
NPS
(inches)
801001401)
3/4 4 1/2 4 1/2 3
1 5 4 1/2 3
1 1/2 5 1/2 5 3
2 5 1/2 5 3
  • 1 ft (foot) = 0.3048 m
  • T (oC) = 5/9 (T (oF) - 32)
1) For temperatures above 140 oF continuous support of the pipes is needed.
PVDF is recognized by its high mechanical strength and excellent chemical resistance even at higher temperatures.
Dimensions of Pipes and Tubes
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Electric Motors - 230 & 460V Three Phase Circuits Wiring
Sizing of copper wire and transformers for three phase 230 & 460V electrical motors.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Piping Elbows - Thrust Block Forces
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
Steel Pipes - Supports
Recommended max. distance between steel pipe supports.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
