The stress in a steam boiler shell can be calculated as
σ = P D / 2 t (1)
σ = hoop stress (Pa, N/m2)
P = boiler pressure (Pa, N/m2)
D = diameter of boiler shell (m)
t = thickness of boiler shell (m)
• Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
Boiler - Efficiency
Combustion gross and net calorific value.
Boiler Blowdown
Boiler Blowdown Rate
Calculate boiler blowdown rate.
Boiler Capacities
Steam boilers output can be expressed in Boiler Horsepower, MBTU or in Pounds of Steam delivered per hour.
Boilers - Classification
Classification of boilers according the ASME Boiler and Pressure Vessel Code.
Stress
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
