Properties of steam at varying pressures and temperatures:
For full table with Entropy - rotate the screen!
Absolute pressure (kPa, kN/m2) | Evaporation Temperature (oC) | Specific Volume (m3/kg) | Density - ρ - (kg/m3) | Specific Enthalpy of | Specific Entropy of Steam - s - (kJ/kgK) | ||
Liquid - hl - (kJ/kg) | Evaporation - he - (kJ/kg) | Steam - hs - (kJ/kg) | |||||
0.8 | 3.8 | 160 | 0.00626 | 15.8 | 2493 | 2509 | 9.058 |
2.0 | 17.5 | 67.0 | 0.0149 | 73.5 | 2460 | 2534 | 8.725 |
5.0 | 32.9 | 28.2 | 0.0354 | 137.8 | 2424 | 2562 | 8.396 |
10.0 | 45.8 | 14.7 | 0.0682 | 191.8 | 2393 | 2585 | 8.151 |
20.0 | 60.1 | 7.65 | 0.131 | 251.5 | 2358 | 2610 | 7.909 |
28 | 67.5 | 5.58 | 0.179 | 282.7 | 2340 | 2623 | 7.793 |
35 | 72.7 | 4.53 | 0.221 | 304.3 | 2327 | 2632 | 7.717 |
45 | 78.7 | 3.58 | 0.279 | 329.6 | 2312 | 2642 | 7.631 |
55 | 83.7 | 2.96 | 0.338 | 350.6 | 2299 | 2650 | 7.562 |
65 | 88.0 | 2.53 | 0.395 | 368.6 | 2288 | 2657 | 7.506 |
75 | 91.8 | 2.22 | 0.450 | 384.5 | 2279 | 2663 | 7.457 |
85 | 95.2 | 1.97 | 0.507 | 398.6 | 2270 | 2668 | 7.415 |
95 | 98.2 | 1.78 | 0.563 | 411.5 | 2262 | 2673 | 7.377 |
100 | 99.6 | 1.69 | 0.590 | 417.5 | 2258 | 2675 | 7.360 |
101.331) | 100 | 1.67 | 0.598 | 419.1 | 2257 | 2676 | 7.355 |
110 | 102.3 | 1.55 | 0.646 | 428.8 | 2251 | 2680 | 7.328 |
130 | 107.1 | 1.33 | 0.755 | 449.2 | 2238 | 2687 | 7.271 |
150 | 111.4 | 1.16 | 0.863 | 467.1 | 2226 | 2698 | 7.223 |
170 | 115.2 | 1.03 | 0.970 | 483.2 | 2216 | 2699 | 7.181 |
190 | 118.6 | 0.929 | 1.08 | 497.8 | 2206 | 2704 | 7.144 |
220 | 123.3 | 0.810 | 1.23 | 517.6 | 2193 | 2711 | 7.095 |
260 | 128.7 | 0.693 | 1.44 | 540.9 | 2177 | 2718 | 7.039 |
280 | 131.2 | 0.646 | 1.55 | 551.4 | 2170 | 2722 | 7.014 |
320 | 135.8 | 0.570 | 1.75 | 570.9 | 2157 | 2728 | 6.969 |
360 | 139.9 | 0.510 | 1.96 | 588.5 | 2144 | 2733 | 6.930 |
400 | 143.1 | 0.462 | 2.16 | 604.7 | 2133 | 2738 | 6.894 |
440 | 147.1 | 0.423 | 2.36 | 619.6 | 2122 | 2742 | 6.862 |
480 | 150.3 | 0.389 | 2.57 | 633.5 | 2112 | 2746 | 6.833 |
500 | 151.8 | 0.375 | 2.67 | 640.1 | 2107 | 2748 | 6.819 |
550 | 155.5 | 0.342 | 2.92 | 655.8 | 2096 | 2752 | 6.787 |
600 | 158.8 | 0.315 | 3.175 | 670.4 | 2085 | 2756 | 6.758 |
650 | 162.0 | 0.292 | 3.425 | 684.1 | 2075 | 2759 | 6.730 |
700 | 165.0 | 0.273 | 3.66 | 697.1 | 2065 | 2762 | 6.705 |
750 | 167.8 | 0.255 | 3.915 | 709.3 | 2056 | 2765 | 6.682 |
800 | 170.4 | 0.240 | 4.16 | 720.9 | 2047 | 2768 | 6.660 |
850 | 172.9 | 0.229 | 4.41 | 732.0 | 2038 | 2770 | 6.639 |
900 | 175.4 | 0.215 | 4.65 | 742.6 | 2030 | 2772 | 6.619 |
950 | 177.7 | 0.204 | 4.90 | 752.8 | 2021 | 2774 | 6.601 |
1000 | 179.9 | 0.194 | 5.15 | 762.6 | 2014 | 2776 | 6.583 |
1050 | 182.0 | 0.186 | 5.39 | 772 | 2006 | 2778 | 6.566 |
1150 | 186.0 | 0.170 | 5.89 | 790 | 1991 | 2781 | 6.534 |
1250 | 189.8 | 0.157 | 6.38 | 807 | 1977 | 2784 | 6.505 |
1300 | 191.6 | 0.151 | 6.62 | 815 | 1971 | 2785 | 6.491 |
1500 | 198.3 | 0.132 | 7.59 | 845 | 1945 | 2790 | 6.441 |
1600 | 201.4 | 0.124 | 8.03 | 859 | 1933 | 2792 | 6.418 |
1800 | 207.1 | 0.110 | 9.07 | 885 | 1910 | 2795 | 6.375 |
2000 | 212.4 | 0.0995 | 10.01 | 909 | 1889 | 2797 | 6.337 |
2100 | 214.9 | 0.0945 | 10.54 | 920 | 1878 | 2798 | 6.319 |
2300 | 219.6 | 0.0868 | 11.52 | 942 | 1858 | 2800 | 6.285 |
2400 | 221.8 | 0.0832 | 12.02 | 952 | 1849 | 2800 | 6.269 |
2600 | 226.0 | 0.0769 | 13.01 | 972 | 1830 | 2801 | 6.239 |
2700 | 228.1 | 0.0740 | 13.52 | 981 | 1821 | 2802 | 6.224 |
2900 | 232.0 | 0.0689 | 14.52 | 1000 | 1803 | 2802 | 6.197 |
3000 | 233.8 | 0.0666 | 15.00 | 1008 | 1794 | 2802 | 6.184 |
3200 | 237.4 | 0.0624 | 16.02 | 1025 | 1779 | 2802 | 6.158 |
3400 | 240.9 | 0.0587 | 17.04 | 1042 | 1760 | 2802 | 6.134 |
3600 | 244.2 | 0.0554 | 18.06 | 1058 | 1744 | 2802 | 6.112 |
3800 | 247.3 | 0.0524 | 19.08 | 1073 | 1728 | 2801 | 6.090 |
4000 | 250.3 | 0.0497 | 20.09 | 1087 | 1713 | 2800 | 6.069 |
- Vacuum steam is the general term used for saturated steam at temperatures below 100°C.
1) Atmospheric pressure
- Absolute Pressure = Gauge Pressure + Atmospheric Pressure
- Specific enthalpy - or Sensible Heat - is the quantity of heat in 1 kg of water according to the selected temperature
Example - Boiling Water at 100 oC and 0 bar
At atmospheric pressure - 0 bar gauge or absolute 101.33 kN/m2 - water boils at 100 oC. 419 kJ of energy is required to heat 1 kg of water from 0 oC to the saturation temperature 100 oC.
Therefore, at 0 bar gauge (absolute 101.33 kN/m2) and 100 oC - the specific enthalpy of water is 419 kJ/kg.
Another 2257 kJ of energy is required to evaporate the 1 kg of water at 100 oC to steam at 100 oC. Therefore, at 0 bar gauge (absolute 101.33 kN/m2) - the specific enthalpy of evaporation is 2257 kJ/kg.
The total specific enthalpy of the steam (or heat required to evaporate water to steam) at atmospheric pressure and 100 oC can be summarized as:
hs = 419 + 2257
= 2676 kJ/kg
= 2676 (kJ/kg) / 3600 (s/h) = 0.74 kWh/kg
(1 hour = 3600 seconds, 1 kW = 1 kJ/s)
Example - Boiling Water at 170 oC and 7 bar
Steam at atmospheric pressure is of limited practical use since it can not be conveyed by its own pressure along a steam pipe to the points of consumption.
At 7 bar gauge (absolute 800 kN/m2) - the saturation temperature of water is 170 oC. More heat energy is required to raise the temperature to the saturation point at 7 bar gauge than needed for water at atmospheric pressure. From the table a value of 720.9 kJ is needed to raise 1 kg of water from 0 oC to the saturation temperature 170 oC.
The heat energy (enthalpy of evaporation) needed at 7 bar gauge to evaporate the water to steam is actually less than the heat energy required at atmospheric pressure. The specific enthalpy of evaporation decrease with steam pressure increase. The evaporation heat is 2047 kJ/kg according the table.
Note! Because the specific volume of steam decreases with increasing pressure, the amount of heat energy transferred in the same volume actually increases with steam pressure. In other words the same pipe may transfer more energy with high pressure steam than with low pressure steam.
• Flash Steam
Generation of flash steam in steam and condensate systems. Thermodynamic fundamentals, heat loss, energy recovery and more.
• Steam and Condensate
• Thermodynamics
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Condensate Pipes - Flash Steam Generated
Calculate flash steam generation in condensate pipe lines.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Evaporative Cooling
Evaporative cooling tutorial.
Flash Steam Energy Loss
When flash steam is generated and vented to the surroundings a considerable amount of energy is lost
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Steam & Condensate Equations
Steam consumption and condensate generation when heating liquid or gas flows
Steam - Flow vs. kW Rating
Calculate steam flow rate vs. kW rating.
Calculate the stress in steam boiler shells caused by steam pressure.
Steam Consumption for some Typical Steam Heated Consumers
Steam consumption rates for typical steam heated consumers in industries like bakeries, breweries, paper factories etc.
Steam Entropy
Basic steam thermodynamics - entropy diagram.
Steam Heating Air
Steam Heating Systems - Classifications
Steam systems carries heat through pipes from the boiler to consumers as heat exchangers, process equipment etc.
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
Steam Trap Selection Guide
Steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps.
Steam Traps - Back Pressure and Capacity
A back pressure in a condensate systems will reduce steam trap capacity
Superheated Steam - Entropy
The entropy of steam superheated to temperatures above saturation points.
Thermodynamic Properties of Saturated Steam: Data & Charts in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Vapor and Steam
An introduction to vapor and steam.
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water-Steam Mollier Diagram
Wet Steam - Enthalpy
Wet Steam - Quality vs. Dryness Fractions
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
Wet Steam - Specific Volume
Wet steam and specific volume.
