Globe Temperature
The Resultant Temperature, also called the Globe Temperature, can be used as a more representative measure of temperature comfort than air temperature alone.
The Globe temperature can be calculated
tg = 0.5 tmr + 0.5 ta (1)
tg = globe (resultant) temperature (oC, oF)
tmr = mean radiation temperature (oC, oF)
ta = air temperature (oC, oF)
Globe temperatures can be measured with acceptable results in the centre of black globes with diameters ranging 25 - 150 mm.
• Physiology
Clo - Clothing and Thermal Insulation
Clo is used as a measure of clothes thermal insulation.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Indoor Design Temperatures
Recommended indoor temperatures in summer or winter.
Met - Human Metabolic Rates
Metabiolic Rate - Met - is used as a measuring unit for human body heat or power production.
Outdoor Temperatures and Relative Humidity - U.S. Winter and Summer Conditions
Outdoor summer and winter design temperatures and relative humidity for U.S. states and cities.
Predicted Mean Vote Index (PMV)
PMV index predicts mean comfort response of a larger group of people.
Thermocouples
Thermocouples - types, principles and temperature ranges.
