Viscous Liquids - Max. Delivery Flow Velocities
As a rule of thumb - velocities that can be used in design of piping and pumping systems for viscous liquids:
Pipe Dimension | Delivery Velocity | ||
inches | mm | m/s | ft/s |
1 | 25 | 1 | 3.5 |
2 | 50 | 1.1 | 3.6 |
3 | 75 | 1.1 | 3.7 |
4 | 100 | 1.15 | 3.8 |
6 | 150 | 1.2 | 3.9 |
8 | 200 | 1.2 | 4 |
10 | 250 | 1.3 | 4.5 |
12 | 300 | 1.4 | 4.5 |
• Piping Systems
• Pumps
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Steel Pipes Schedule 40 - Velocity Head vs. Water Flow
Velocity head can be used to calculate minor pressure or head loss in fluid flow systems.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
