Light Oil Pumping - Flow Velocities
As a rule of thumb the following velocities can be used in design of piping and pumping systems for light oil transport:
Pipe Dimension | Light Oil Velocity | ||
inches | mm | m/s | ft/s |
1 | 25 | 1 | 3.5 |
2 | 50 | 1.1 | 3.6 |
3 | 75 | 1.15 | 3.8 |
4 | 100 | 1.25 | 4 |
6 | 150 | 1.5 | 4.7 |
8 | 200 | 1.75 | 5.5 |
10 | 250 | 2 | 6.5 |
12 | 300 | 2 | 6.5 |
- More about light oils in Material Properties or Combustion
• Piping Systems
• Pumps
Fuel Oil Pumps - Suction Capacities
Single stage and double stage fuel oil pumps and their suction capacities.
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Oil Fuels - Viscosities vs. Temperatures
Viscosities of fuel oils vs. temperature.
Oil Pipes - Recommended Flow Velocities
Oil pipes flow velocities should be kept within certain limits.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
