PE - Polyethylene High Density Pipes - Weights
Approximately weights of polyethylene high density - PEH - pipes:
Outside Diameter
(mm)
Pressure Rating
PN 2.5PN 4PN 6PN 10PN 16
Pipe Weight (kg/m)
20       0.11 0.16
25     0.13 0.17 0.24
32     0.19 0.28 0.39
40   0.21 0.29 0.44 0.61
50   0.32 0.45 0.68 0.95
63 0.33 0.48 0.70 1.1 1.5
75 0.46 0.69 0.9 1.5 2.1
90 0.65 0.99 1.4 2.2 3.1
110 0.96 1.5 2.1 3.2 4.6
125 1.3 1.9 2.7 4.1 5.9
140 1.6 2.4 3.4 5.2 7.8
160 2.0 3.1 4.4 6.8 9.6
180 2.5 3.9 5.6 8.6 12.1
200 3.1 4.8 6.9 10.6 15.0
225 3.9 6.0 8.7 13.4 19.0
250 4.9 7.4 10.7 16.4 23.4
280 6.1 9.2 13.4 20.6 29
315 7.6 11.8 17.0 26.0 37
355 9.7 14.9 21.6 33.0 47
400 12.3 18.8 27.3 41.9 60
450 15.9 24.3 35.3 54.3 77
500 19.7 30.0 43.0 67
560 24.5 37.7 54.5 84
600 26.9 43.7 63 96
630 31.0 47.7 69 106
710 39.5 60.5 88
800 50 77 111
900 63 97 141
1000 78 120 173
1200 112 172
1400
1600 199 306
PE pipes are produced in different pressure grades - PN grades - indicating the pressure in bars the pipe can support with water at 20 oC.
The pressure grades available according to European standards are
  • PN 2.5 - max pressure 2.5 bar
  • PN 4 - max pressure 4 bar
  • PN 6 - max pressure 6 bar
  • PN 10 - max pressure 10 bar
  • PN 16 - max pressure 16 bar
  • 1 bar = 105 Pa (N/m2) = 0.1 N/mm2 = 10.197 kp/m2 = 10.20 m H2O = 0.9869 atm = 14.50 psi (lbf/in2) = 106 dyn/cm2 = 750 mmHg
Dimensions of Pipes and Tubes
Bending PE Pipes
Bending PE pipe calculator.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
