Fluid Flow - Hydraulic Diameter
Hydraulic diameter - dh - is the "characteristic length" used to calculate the dimensionless Reynolds Number to determine if a flow is turbulent or laminar. A flow is
  • laminar if Re < 2300
  • transient for 2300 < Re < 4000
  • turbulent if Re > 4000
Note that the velocity in the Reynolds equation is based on actual cross section area of duct or pipe.
The hydraulic diameter is used the Darcy-Weisbach equation to calculate pressure loss in ducts or pipes.
Note! - the hydraulic diameter is not the same as the geometrical equivalent diameter of non-circular ducts or pipes.
Hydraulic diameter can be calculated with the generic equation
dh = 4 A / p                               (1)
dh = hydraulic diameter (m, ft)
A = area section of the duct or pipe (m2, ft2)
p = "wetted" perimeter of the duct or pipe (m, ft)
Note! - inches are commonly used in the Imperial unit system
Hydraulic Diameter of a Circular Tube or Duct
Based on equation (1) the hydraulic diameter of a circular duct can be expressed as:
dh = 4 π r2 / (2 π r)
    = 2 r
    = d                                  (2)
r = pipe or duct inside radius  (m, ft)
d = pipe or duct inside diameter  (m, ft)
As we could expect the hydraulic diameter of a standard circular tube or duct is the inner diameter or two times the inner radius.
Hydraulic Diameter of Circular Tube with Circular Tube on the Inside
The flow is in the volume between the inside and outside pipe.
Based on equation (1) the hydraulic diameter of a circular duct or tube with an inside duct or tube can be expressed as
dh = 4 (π ro2 -π ri2) / (2 π ro + 2 π ri)
    = 2 (ro - ri)                                        (3)
ro = inside radius of the outside tube (m, ft)
ri = outside radius of the inside tube (m, ft)
Hydraulic Diameter of Rectangular Tubes or Ducts
Based on equation (1) the hydraulic diameter of a rectangular duct or pipe can be calculated as
dh= 4 a b / (2 (a + b))
    = 2 a b / (a + b)                                 (4)
a = width/height of the duct (m, ft)
b = height/width of the duct (m, ft)
Related Mobile Apps from The EngineeringToolBox
Rectangular to Circulate Duct/Tube Hydraulic Diameter Calculator
The calculator below is based on formula (4) an can be used to calculate the hydraulic diameter of rectangular duct or tube. The formula is generic and any unit can be used.
Equivalent diameter
Note! The hydraulic diameter is not the same as the equivalent diameter. The equivalent diameter is the diameter of a circular duct or pipe that gives the same pressure loss as a rectangular duct or pipe.
Fluid Mechanics
Ventilation Systems
Air Duct Friction Loss: Pressure Drop Calculator & Chart
Head loss or major loss in air ducts - equations and online calculator for rectangular and circular ducts - Imperial and SI units.
Colebrook Equation
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Ducts - Cross-Sectional Area vs. Diameter
Circular ducts sross-sectional areas.
Equivalent Length vs. Minor Pressure Head Loss in Pipe and Duct Components
Minor pressure and head loss in pipes vs. equivalent length in tubes and duct systems.
Flow Section Channels - Geometric Relationships
Geometric relationships like area, wetted perimeter and hydraulic diameter.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
Hazen-Williams Pressure Loss Equation
The Hazen-Williams equation can be used to calculate the pressure drop (psi) or friction loss in pipes or tubes.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Pipe and Duct Systems - Total Head Loss
Major and minor loss in pipes, tubes and duct systems.
Rectangular Ducts - Hydraulic Diameter
Calculate hydraulic diameter for rectangular ducts - metric units.
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
