Cast Iron Threaded Pipe Fittings - Working Pressures vs. Temperature
Maximum working pressures of cast iron pipe fittings - threaded fittings according ANSI B16.4:
Temperature (oF) | Maximum Working Pressure (psig) | |
Pressure Class | ||
125 | 250 | |
-20 to 150 | 175 | 400 |
200 | 165 | 370 |
250 | 150 | 340 |
300 | 140 | 310 |
350 | 125 | 280 |
400 | - | 250 |
• Pressure Ratings of Pipes and Fittings
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Cast Iron Flanged Pipe Fittings - Working Pressures vs. Temperature
Maximum working pressures for cast iron flanged pipe fittings according ANSI B16.1.
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Cast Iron Flanges - ASME/ANSI Class 250
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 250 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
Malleable Iron Threaded Fittings - Pressure vs. Temperature Rating
ASME/ANSI B16.3 Malleable Iron Threaded Fittings - Pressure and Temperature Ratings.
PN Pressure Ratings for Flanges: Specifications & Standards
