California Pipe Flow Metering Method
With the California Pipe Flow Metering Method the discharge from the open end of partially filled horizontal pipes discharging freely into the air can be measured.
The discharge can be calculated as
q = 8.69 (1 - a / d)1.88 d2.48 (1)
q = discharge (ft3/s)
a = distance in the plane end of the pipe - from the top of the inside surface of the pipe - to the water surface (ft)
d = internal diameter of pipe (ft)
The equation is empirical and can be used for pipes in the diameter range 3 - 10 in.
- 1 mm = 0.00328 feet
- 1 ft = 0.3048 m = 12 in = 0.3333 yd = 30.48 cm = 304.8 mm
- 1 ft3/s = 0.0283168 m3/s = 101.9 m3/h = 28.32 dm3(litre)/s = 60 ft3/min = 373.7 Imp.gal (UK)/min = 448.9 gal (US)/min (US gpm)
California Pipe Flow Example
In the discharge on a horizontal 4 inches PVC sewer pipe the distance from the top inside pipe to the water flow is 3 inches (0.25 ft). The inside diameter of the PVC pipe is 4.069 in (0.34 ft).
q = 8.69 (1 - (0.25 ft) / (0.34 ft))1.88 (0.34 ft)2.48
= 0.049 ft3/s
California Pipe Flow Calculator - Imperial Units
California Pipe Flow Calculator - Metric Units
• Flow Measurements
• Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Comparing Flowmeters
A limited comparison of flowmeter principles - regarding service, rangeability, pressure loss, typical accuracy, upstream pipe diameters, viscosity and relative costs.
Flow Section Channels - Geometric Relationships
Geometric relationships like area, wetted perimeter and hydraulic diameter.
Flowmeter - Accuracy
Flowmeters - Turndown Ratios
Turndown ratio (Rangeability) can be used to compare flow measurement devices like orifices, venturi meters etc.
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Open Channel Weirs - Volume Flow Measurements
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
Orifice, Nozzle, and Venturi Flow Meters: Principles, Calculations & Data
Pitot Tubes
Pitot tubes can be used to measure fluid flow velocities by measuring the difference between static and dynamic pressure in the flow.
Sluice Gate - Volume Flow Measurements
Sluice gates can be used to control and measure volume flow rates in open channels and rivers, mainly in connection to hydro power plants.
Ultrasonic Doppler and Time of Flight Velocity and Volume Flow Meters
An basic introduction to the ultrasonic Doppler and Time of Flight Flow Meters.
Vortex Flowmeters - Shedding Frequency vs. Volume Flow Rate
The vortex shedding frequency created around a bluff body and flow rate.
Water - Volume Flow Measurement
A manual providing guidance in selecting, managing, inspecting, and maintaining water measurement devices - describes standard methods and devices commonly used to measure irrigation water.
