Arsenic - Melting Points of Binary Eutectic Alloys
The melting point of an alloy of two (binary) or more metals depends on the relative proportions of the ingredients.
- an eutectic mixture is the mixture where the melting point is as low as possible
Binary eutectic Arsenic - As - alloys, with composition and melting points are indicated below:
Alloy Component | Weight of Alloy Component (%) | Melting Point | |
K | oF | ||
Co - Cobalt | 70 | 1189 | 1681 |
Cu - Copper | 78 | 958 | 1265 |
Fe - Iron (Ferrum) | 69 | 1103 | 2017 |
In - Indium | 18 | 1004 | 1348 |
Mn - Manganese | 49 | 1143 | 1598 |
Ni - Nickel | 57 | 1077 | 1479 |
Sb - Antimony (Stibium) | 87 | 878 | 1121 |
Sn - Tin (Stannum) | 51 | 852 | 1074 |
Zn - Zinc | 18 | 996 | 1333 |
- T (oC) = 5/9 (T (oF) - 32)
• Melting and Freezing Points
Elements - Melting Points
Melting points of elements.
Metal Alloys - Melting Points
Alloys and their melting points.
Molybdenum Binary Eutectic Alloys - Melting Points
Mo - Molybdenum - binary eutectic alloys and melting points.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
