Hoses - Pressure Loss vs. Water Flow
Water flow through hoses and pressure loss due to friction:
Nominal diameters are used in the chart.
Hoses -  Internal Diameter vs. External Nominal Diameter
Hose Nominal Diameter
(inches)
Internal Diameter
(inches)
1/8 0.125
3/16 0.1875
1/4 0.25
5/16 0.3125
3/8 0.375
7/16 0.4375
1/2 0.5
5/8 0.625
3/4 0.75
7/8 0.875
1 1
1 1/4 1.25
1 1/2 1.5
2 2
2 1/2 2.5
3 3
3 1/2 3.5
4 4
5 5
6 6
Example - Water Flow through a Hose and Pressure Loss
2 gpm (7.6 liter/min) flows through a 1/2" garden hose with length 82 feet (25 m). From the diagram above the pressure loss per 100 feet can be estimated to 5 psi. The pressure drop in the hose can be calculated as
(5 psi/100 ft) ((80 ft) / (100 ft)) = 4 psi (0.28 bar)
Farm Livestock - Animals and Water Consumption
Average daily water consumption of various farm animals, including cattle, horses, sheep, and poultry.
Hoses - Water Volume Discharge Flow vs. Pressure
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Jet Propulsion
Calculate the propulsive discharge force or thrust induced by an incompressible jet flow.
Vertical Pipes - Discharge Height vs. Volume Flow
Volume flow and discharge height from vertical water pipes.
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
