Three-Phase Power - Equations
Most AC power today is produced and distributed as three-phase power where three sinusoidal voltages are generated out of phase with each other. With single-phase AC power there is only one single sinusoidal voltage.
Real Power
Line to line voltage:
Wapplied = 31/2 Ull I cos(Φ)
= 31/2 Ull I PF                      (1)
Wapplied = real power (W, watts)
Ull = line to line voltage (V, volts)
I = current (A, amps)
PF = cos Φ
= power factor (0.7 - 0.95)
Line to neutral voltage:
Wapplied = 3 Uln I cos(Φ)                    (2)
Uln = line to neutral voltage (V, volts)
For pure resistive load: PF = cos Φ = 1
  • resistive loads converts current into other forms of energy, such as heat
  • inductive loads use magnetic fields like motors, solenoids, and relays
Power Factor
Typical power factors:
Three-Phase Power Factors
DevicePower Factor
Lamp, fluorecent uncompensated 0.5
Lamp, fluorecent compensated 0.93
Lamp, incandescent 1
Motor, induction 100% load 0.85
Motor, induction 50% load 0.73
Motor, induction 0% load 0.17
Motor, synchronous 0.9
Oven, resistive heating element 1
Oven, induction compensated 0.85
Pure resistive load 1
Example - Pure Resistive Load
For pure resistive load and power factor = 1 the real power in a 400/230 voltage (line to line / line to neutral) 20 amps circuit can be calculated as
W applied = 3 1/2 (400 V) (20 A) 1
= 13856 W
= 13.9 kW
Total Power
W = 31/2 U I                       (2)
Brake Horsepower
  • Brake horsepower is the actual power delivered to or by a shaft.
WBHP = 31/2 U I PF μ / 746                       (3)
WBHP = brake horse power (hp)
μ = device efficiency
Electrical
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
AC Circuits - Power vs. Voltage and Current
The alternating current In an AC circuit is generated by a sinusoidal voltage source.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Electric Motors - Efficiency
Electrical Equipment - Power Consumption
Typical power consumption and running time for common electrical equipment.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Induction Motors - Slip
Slip is the difference between an electrical induction motor's synchronous and asynchronous speed.
Electrical Motors - Service Factors
Service factor - SF - is a measure of periodically overload capacity at which a motor can operate without beeing damaged.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
Electrical Vehicle Charging - Power vs. Voltage and Amps
EV Charging - AC vs. DC, single phase vs. three phase and power vs. voltage and amps.
Law of Cosines
One side of a triangle when the opposite angle and two sides are known.
Measurement of Electrical Power
Measure electric power with an ammeter and a voltmeter.
Power
Single Phase Power Equations
Power equations for single phased electrical systems.
