Use of Telephones in Noisy Areas
Background noise interferes with telephone conversations, and
  • conditions are satisfactory at levels less than 65 SIL (dB) (approx. 72 dBA)
  • conditions are difficult at levels in the range 65 - 80  SIL (dB) (approx. 72 - 87 dBA)
  • conditions are impossible at levels above 80  SIL (dB) (approx. 87 dBA)
SIL - Speech Interference Levels
Acoustics
Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Noise Criterion vs. Noise Rating and dB(A)
Comparing Noise Criterion (NC, NCB, RNC) to Noise Rating (NR) and dB(A).
SIL - the Speech Interference Levels
Background noise frequencies that interferes with speech.
Sound Power
Sound Pressure Level
