Staircase Calculator
The calculator can be used to calculate unit rise and run of straight stairs.
  • Unit rise:
  • Unit run:
  • Elevation angle: degrees
  • Offset steps:
General guidelines
  • unit run should not be less than 10 inches (25 cm)
  • unit rise should not exceed 7 3/4 inches (20 cm)
Add 3D Stairs to Sketchup Models
Miscellaneous
Building Tolerances
Typical tolerances for floors, walls, columns and more.
Human Effort Levels - Energy and Heart Rates
Human work effort levels vs. energy expenditure and associated heart rates.
Infiltration - Heat Losses from Buildings
Estimated infiltration heat losses from buildings.
Recommended Air Change Rates for Different Room Types
Fresh air (make up air) rquirements - or recommended air change rates (ACH) for typical rooms and buildings like auditoriums, kitchens, churches and more.
Required Room Space per Person
Room area per person - may be used to calculate typical indoor climate loads.
U.S. Standard Architectural Drawing Sizes
US architectural drawing sizes and formats.
Work done by Force
Work done by a force acting on an object.
