Squaring with Diagonal Measurements
A rectangle where both lengths (a) and both widths (b) are equal is square if length of both diagonals are equal!
A = B                                  (1)
A, B = diagonal measurements (m, ft ..)
Mathematics
Area Survey App
Online app that can be used to make an exact plot of a surveyed area - like a room, a property or any 2D shape.
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circles on the Outside of a Circle
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Law of Sines
Calculate the angles in a generic triangle.
Law of Tangents
Triangles and law of tangents.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Solids - Volumes and Surfaces
The volume and surface of solids like rectangular prism, cylinders, pyramids, cones and spheres - online calculator.
Trigonometric Functions
Sine, cosine and tangent - the natural trigonometric functions.
