Spiral Ducts - Dimensions
Physical properties of spiral pipe - imperial units - are indicated below.
Nominal Diameter | Outside Diameter | Wall Thickness | Weight |
(in) | (in) | (in) | (lb/ft) |
3 | 3 | 0.0276 | 1.1 |
4 | 4 | 0.0276 | 1.4 |
5 | 5 | 0.0276 | 1.7 |
6 | 6 | 0.0276 | 2.0 |
7 | 7 | 0.0276 | 2.4 |
8 | 8 | 0.0276 | 2.8 |
9 | 9 | 0.0276 | 3.1 |
10 | 10 | 0.0276 | 3.4 |
11 | 11 | 0.0276 | 3.8 |
12 | 12 | 0.0276 | 4.1 |
13 | 13 | 0.0276 | 4.5 |
14 | 14 | 0.0276 | 4.8 |
15 | 15 | 0.0276 | 5.1 |
16 | 16 | 0.0276 | 5.5 |
17 | 17 | 0.0276 | 5.8 |
18 | 18 | 0.0276 | 6.1 |
20 | 20 | 0.0276 | 6.8 |
22 | 22 | 0.0336 | 9.1 |
24 | 24 | 0.0336 | 9.9 |
26 | 26 | 0.0336 | 10.8 |
28 | 28 | 0.0336 | 11.6 |
30 | 30 | 0.0336 | 12.4 |
32 | 32 | 0.0336 | 13.3 |
34 | 34 | 0.0336 | 14.1 |
36 | 36 | 0.0336 | 14.9 |
38 | 38 | 0.0396 | 18.5 |
40 | 40 | 0.0396 | 19.5 |
42 | 42 | 0.0396 | 20.5 |
44 | 44 | 0.0396 | 21.5 |
46 | 46 | 0.0396 | 22.5 |
48 | 48 | 0.0396 | 23.4 |
50 | 50 | 0.0516 | 32.4 |
52 | 52 | 0.0516 | 33.7 |
54 | 54 | 0.0516 | 35.0 |
56 | 56 | 0.0516 | 36.3 |
58 | 58 | 0.0516 | 37.6 |
60 | 60 | 0.0516 | 38.8 |
62 | 62 | 0.0516 | 41.1 |
64 | 64 | 0.0516 | 43.4 |
66 | 66 | 0.0516 | 44.7 |
68 | 68 | 0.0516 | 46.1 |
70 | 70 | 0.0516 | 47.4 |
72 | 72 | 0.0516 | 48.8 |
• Ventilation Systems
Air Duct Friction Loss: Pressure Drop Calculator & Chart
Head loss or major loss in air ducts - equations and online calculator for rectangular and circular ducts - Imperial and SI units.
Circular Ducts - Dimensions
Standard size of circular ventilation air ducts.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum sizes of ducts or pipes through K series joists.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
HVAC Ducts - Air Velocities
Recommended air velocities in HVAC ducts.
