Waste Water Piping - Flow Capacitiy vs. Dimension
In sewage piping and pumping systems the flow velocity must exceed certain limits to maintain trouble free operation and to avoid settling and sedimentation of solids:
- for horizontal wastewater pipe systems with solids the speed should exceed 3 ft/sec
- for wastewater water system with organic solids the speed should exceed 2 ft/sec
On the other hand, the flow velocity should not exceed certain limits to avoid potential wear and tear due to erosion and abrasion:
- the flow velocity in high-grit sewage handling systems should not exceed 12 ft/sec
- the flow velocity in sewage systems with low grit concentrations should not exceed 18 ft/sec
Flow rate capacities in U.S. gal for sewage piping and pumping systems within the limitations:
Pipe Dimension (inches) | Flow Rate (US GPM) | |||
Minimum Velocity | Maximum Velocity | |||
2 ft/sec (0.6 m/s) | 3 ft/sec (0.9 m/s) | 12 ft/sec (3.6 m/s) | 18 ft/sec (5.4 m/s) | |
3 | 45 | 65 | 270 | 400 |
4 | 80 | 120 | 480 | 700 |
6 | 180 | 260 | 1050 | 1600 |
8 | 300 | 500 | 1900 | 2800 |
10 | 500 | 750 | 3000 | 4400 |
12 | 700 | 1100 | 4300 | 6400 |
Note! - based on clean pipes. The friction coefficient may vary with the pipe material.
• Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding.
Drain Pipes and Vent Stacks
Drain pipes and vent stack sizing.
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out .
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Open Channel Weirs - Volume Flow Measurements
Weirs can be used to measure flow rates in open channels and rivers - common for water supply and sewage plants.
Pipes - Relative Capacity
Relative capacity between larger and smaller pipes.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
Septic Systems
Septic systems handles waste from drain systems.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
