Salt Hydrates - Melting points and Latent Melting Energy
The latent heat of melting salt hydrates can be used for storing energy.
Salt HydrateMelting Point
(oC)
Latent Melting Heat
(MJ/m3)
CaCl2 (Calcium Chloride) 6H2O 29 281
Na2SO4 (Sodium Sulfate) 10H2O 32 342
Na2CO3 (Sodium Carbonate) 10H2O 33 360
Na2HPO4 (Dibasic Sodium Orthophosphate) 12H2O 35 205
Na2HPO4 (Dibasic Sodium Orthophosphate) 7H2O 48 302
Na2S2O3 (Sodium Thiosulphate) 5H2O 48 346
Ba(OH)2 (Barium Hydroxide) 8H2O 78 655
Melting and Freezing Points
Thermodynamics
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points.
Energy
Energy is the capacity to do work.
Energy Accumulated in Heated Water - kWh
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Heat, Work and Energy
Heat vs. work vs. energy.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Potential Energy - Hydropower
Storing Thermal Heat
Energy stored as sensible heat in different types of materials.
