Refrigeration Formulas
Compression Work
Compressor work can expressed as
W = h q                                                    (1)
W = compression work (Btu min)
h = heat of compression (Btu/lb)
q = refrigerant circulated (lb/min)
Compression Horsepower
Compression horsepower can be expressed as
P = W / 42.4                                                (2)
P = compression power (hp)
Alternatively
P = c / (42.4 COP)                                          (2b)
c = capacity (Btu/min)
COP = coefficient of performance
Compression horsepower per Ton
p = 4.715 / COP                                             (2c)
p = compressor horsepower per Ton (hp/Ton)
COP - Coefficient of Performance
COP = NRE / h                                            (3)
COP = Coefficient of Performance
NRE = Net Refrigeration Effect (Btu/lb)
Net refrigeration effect can be expressed as
NRE = h l - h e                                               (4)
hl = enthalpy of vapor leaving evaporator (Btu/lb)
he = enthalpy of vapor entering evaporator (Btu/lb)
Capacity
c = q NRE                                                  (5)
Compressor Displacement
d = c v / NRE                                             (6)
d = compressor displacement (ft3/min)
v = volume of gas entering compressor (ft3/lb)
Heat of Compression
h = hlc - hec                                            (7)
hlc = enthalpy of vapor leaving compressor (Btu/lb)
hec = enthalpy of vapor entering compressor (Btu/lb)
Volumetric Efficiency
μ = 100 wa / wt                                    (8)
μ = volumetric efficiency
wa = actual weight of refrigerant
wt = theoretical weight of refrigerant
Compression Ratio
CR = ph / ps                                    (9)
CR = compression rate
ph = head pressure absolute (psia)
ps = suction pressure, absolute (psia)
Air Conditioning Systems
Calculating Cooling Loads
Calculating chiller and cooling tower refrigeration loads - in tons.
Cooling Load - Convert between kW/ton to COP or EER
Convert between cooling load units like kW/ton, COP and EER.
Cooling Power vs. Airflow and Duct Sizes
Typical relations between cooling power (tons cooling), air flow and duct size
The quantity of heat absorbed from a refrigerated space.
Refrigerants - Environmental Properties
Physical and environmental properties of some common refrigerants.
Refrigeration Machinery - Required Ventilation
Ventilation required for refrigeration machinery and compressors in hot areas.
