Rainfall Units Converter
Rainfall Convertions
(inches/hour)
(gal/(h ft2))
(gal/(min ft2))
2.5 1.56 0.026
2.4 1.50 0.025
2.3 1.43 0.024
2.2 1.37 0.023
2.1 1.31 0.022
2.0 1.25 0.021
1.9 1.18 0.020
1.8 1.12 0.019
1.7 1.06 0.018
1.6 1.00 0.017
1.5 0.94 0.016
1.4 0.87 0.015
1.3 0.81 0.014
1.2 0.75 0.013
1.1 0.69 0.011
1.0 0.62 0.010
  • 1 in (inch) = 25.4 mm
  • 1 gph = 0.0012 l/s
  • 1 ft2 = 0.093 m2
Weight of Rainfall
Rainfall - Weights
Amount of Rain
(in)
Weight of Water
(lb/ft2)
6 31.2
5 26.0
4 20.8
3 15.6
2 10.4
1 5.2
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Horizontal Storm Drain Piping
Capacities of horizontal storm drain piping systems.
Rainfall Draining of Roof Areas and Vertical Downspouts
Capacities of vertical downspouts when draining roof areas in rainfall.
Rainfall on Roofs and Gutter Slopes
Draining of roof areas and recommended gutter slopes
Storm-Water Conductors
Roof drain capacities.
Storm-Water Runoff Coefficients vs. Surface
Storm-water runoff coefficients for various surfaces
