Pump Head and Pressure: Conversion, Calculations, and Charts
Pumps characteristic curves are often in head - feet or metres - and a conversion to pressure scales commonly used in pressure gauges - like psi or bar - may be required.
Converting Head to Pressure
Converting head in feet to pressure in psi
Pumps characteristic curves in feet of head can be converted to pressure - psi - by the expression:
p = 0.433 h SG                            (1)
p = pressure (psi)
h = head (ft)
SG = specific gravity of the fluid
Converting head in metre to pressure in bar
Pumps characteristic curves in metre of head can be converted to pressure - bar - by the expression:
p = 0.0981 h SG                          (2)
h = head (m)
p = pressure (bar)
Converting head in metre to pressure in kg/cm2
Pumps characteristic curves in metre of head can be converted to pressure - kg/cm2 - by the expression:
p = 0.1 h SG                          (2b)
h = head (m)
p = pressure (kg/cm2)
Converting Pressure to Head
Since pressure gauges often are calibrated in pressure - psi or bar - a conversion to the heads commonly used in pump curves - like feet or meter - may be required.
Converting pressure in psi to head in feet
h = 2.31 p / SG                          (3)
h = head (ft)
p = pressure (psi)
Converting pressure in bar to head in metre
h = p 10.197 / SG                          (4)
h = head (m)
p = pressure (bar)
Converting pressure in kg/cm2 to head in metre
h = p 10 / SG                           (4b)
h = head (m)
Example - Converting Pump Head - feet - to Pressure - psi
The pressure - psi - of a water pump operating with head 120 ft and SG = 1 can be calculated with eq. 1 as:
p = 0.433 (120 ft) (1)
    = 52 psi
Example - Converting Pressure - psi - to Pump Head - feet
The head in feet water column with SG = 1 can be calculated from pressure 100 psi with eq. 3 as:
h = 2.31 (100 psi) / (1)
   = 231 ft
Where specific gravity of water = 1.
Feet of Head Water to psi
Pumps - Water Head vs. Pressure
Head
(ft)
Pressure
(psi)
1 0.43
2 0.87
3 1.30
4 1.73
5 2.17
6 2.60
7 3.03
8 3.46
9 3.90
10 4.33
20 8.66
30 13.0
40 17.3
50 21.7
60 26.0
70 30.3
80 34.7
90 39.0
100 43.3
120 52.0
140 60.6
160 69.3
180 78.0
200 86.6
250 108
300 130
350 152
400 173
500 217
600 260
700 303
800 346
900 390
1000 433
  • water at 62°F (17°C)
Download pressure vs head imperial units as pdf file
Download water pressure vs head - SI units as pdf file
Head vs. Pressure when handling Liquids of different Density
Head vs. Pressure - Liquids of different Density
LiquidSpecific GravityHead
(ft)
Pressure
(psi)
Water 1.0 100 43.3
Kerosene 0.8 100 36.6
Sulphuric Acid 1.8 100 77.9
Identical pumps will develop the same head when running at the same speed but the discharge pressure is quite different due to the different densities of the liquids. It can be simpler to discuss the performance pumps in terms of head rather than pressure since the use of head makes the pump curve applicable to any liquid regardless of density.
Pumps
Centrifugal Pumps
Centrifugal Pumps - Capacity Modulation
Modulating pumps to adapt capacities to variable process demands.
Centrifugal Pumps - Stable and Unstable Flow
The characteristics of stable and unstable flow.
Required power to pump water.
Pipe and Duct Systems - Total Head Loss
Major and minor loss in pipes, tubes and duct systems.
Pressure to Head Unit Converter
Pressure vs. head units - like lb/in2, atm, inches mercury, bars, Pa and more.
Pumps and Fans - Energy Equation and Head Rise
The energy equation can be used to calculate the head rise in pumps and fans.
Static Pressure vs. Head
Water Pressure vs. Head
Pressure in pounds per square inch (psi) vs. head in feet of water (ft h2o).
