Polyester Ropes - Strengths
Polyester rope is made from continuous filament polyester.
Minimum breaking strength and safe load for polyester rope:
Rope Diameter | Minimum Breaking Strength | Safe Load (Safety Factor 12) | Weight | ||||
(in) | (mm) | (lbf) | (kN) | (lbf) | (kN) | (lbm/ft) | (kg/m) |
3/16 | 5 | 765 | 3.40 | 63.8 | 0.284 | 0.011 | 0.016 |
1/4 | 6 | 1315 | 5.85 | 110 | 0.487 | 0.020 | 0.029 |
5/16 | 8 | 2050 | 9.1 | 171 | 0.760 | 0.031 | 0.045 |
3/8 | 10 | 2900 | 12.9 | 242 | 1.07 | 0.044 | 0.065 |
7/16 | 11 | 3915 | 17.4 | 326 | 1.45 | 0.059 | 0.088 |
1/2 | 12 | 5085 | 22.6 | 424 | 1.88 | 0.077 | 0.115 |
9/16 | 14 | 6435 | 28.6 | 536 | 2.39 | 0.098 | 0.146 |
5/8 | 16 | 7825 | 34.8 | 652 | 2.90 | 0.120 | 0.179 |
3/4 | 18 | 11200 | 49.8 | 933 | 4.15 | 0.172 | 0.256 |
7/8 | 22 | 15225 | 67.7 | 1270 | 5.65 | 0.234 | 0.348 |
1 | 24 | 19775 | 88.0 | 1650 | 7.34 | 0.304 | 0.452 |
1 1/16 | 26 | 22225 | 99 | 1850 | 8.23 | 0.342 | 0.509 |
1 1/8 | 28 | 24800 | 110 | 2070 | 9.21 | 0.385 | 0.573 |
1 1/4 | 30 | 29800 | 133 | 2480 | 11.0 | 0.465 | 0.692 |
1 3/8 | 32 | 32500 | 145 | 2710 | 12.1 | 0.465 | 0.759 |
1 1/2 | 36 | 42200 | 188 | 3520 | 15.7 | 0.51 | 0.997 |
1 5/8 | 40 | 49250 | 219 | 4100 | 18.2 | 0.67 | 1.16 |
1 3/4 | 44 | 57000 | 254 | 4750 | 21.1 | 0.78 | 1.35 |
2 | 48 | 72000 | 320 | 6000 | 26.7 | 0.91 | 1.74 |
Example - Maximum Safe Mass for a 3/8" Polyester Rope
The relationship between mass and force (weight) can be expressed as
m = F / g (1)
F = force, weight (N)
m = mass (kg)
Maximum safe mass for a 3/8" polyester rope where safe load is 1.07 kN can be calculated as
m = (1.07×103 N) / (9.81 m/s2)
= 109 kg
Polyester Rope Safe Load Chart
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Cable Loads
Force and tension in cables with uniform loads.
Manila Ropes - Strength
Minimum breaking strength and safe load of manila 3-strand rope.
Nylon Ropes - Strengths
Nylon 3-strand and 8-strand rope - minimum breaking strength and safe load.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyester Polyolefin Ropes - Strengths
Polyester Polyolefin dual fiber 3-strand rope - minimum breaking strength and safe load.
Polypropylene Fiber Ropes - Strengths
Polypropylene fiber 3-strand and 8 strand rope - minimum breaking strength and safe load.
Pulleys
Pulleys, blocks and tackles.
Sisal Ropes - Strengths
Sisal rope 3-strand, minimum breaking strength and safe load.
Winches
Effort force to raise a load.
Wire Rope Slings
Wire Ropes - Strengths
6 strand x 19 wire (6x19) - minimum breaking strength, safe loads and weight.
