Abbreviations, letter tags and label coloring for mechanical, plumbing and piping systems are based on
- ASME A13.1 ‑ Scheme for the Identification of Piping Systems.
- NFPA 99 – Standard for Health Care Facilities.
- NFPA 13 – Installation of Sprinkler Systems.
- NFPA 14 – Installation of standpipe and Hose Systems.
- International Plumbing Code.
Label Abbreviation | System, Pipe Contents | Label Colors (Background - Text) |
CHWR | Chilled Water Return | Green - White |
CHWS | Chilled Water Supply | Green - White |
CWR | Condenser Water Return | Green - White |
CWS | Condenser Water Supply | Green - White |
FOR | Fuel Oil Return | Yellow - Black |
FOS | Fuel Oil Supply | Yellow - Black |
HPC | High Pressure Condensate | Blue - White |
HPS | High Pressure Steam (above 125#) | Blue - White |
HWR | Hot Water Heating Return | Green - White |
HWS | Hot Water Heating Supply | Green - White |
LPC | Low Pressure Condensate | Blue - White |
LPS | Low Pressure Steam (below 25#) | Blue - White |
MPC | Medium Pressure Condensate | Blue - White |
MPS | Medium Pressure Steam (above 25# - below 125#) |
Blue - White |
PCR | Pumped Condensate Return | Blue - White |
ACID | Acid Waste | Orange - Black |
BR | Brine Water | Orange - Black |
FIRE | Fire Suppression Water | Red - White |
HAZ | Hazardous Waste | Orange - Black |
DI or RO | High Purity Water | Green - White |
DCW | Potable Cold Water | Green - White |
DHW | Potable Hot Water Supply | Green - White |
DHWR | Potable Hot Water Return | Green - White |
NG | Natural Gas | Yellow - Black |
LN2 | Nitrogen (liquid) | Black - White |
Med Air | Medical air | Yellow - Black |
CO2 | Carbon dioxide | Gray - White |
He | Helium | Brown - White |
N2 | Nitrogen | Black - White |
N2O | Nitrous oxide | Blue - White |
O2 | Oxygen | Green - White |
Med Vac | Medical?surgical vacuum | White - Black |
WAGD | Waste anesthetic gas disposal | Violet - White |
Lab Air | Laboratory air | Yellow and White checkerboard - Black |
Lab Vac | Laboratory vacuum | White and Black checkerboard - Black boxed |
IA | Instrument air | Red - White |
CFHE | Chemical Fume Hood Exhaust | Purple - White |
BCE | Biosafety Cabinet Exhaust | Purple - White |
RE | Radioisotope Exhaust | Yellow - magenta |
ETOE | ETO Exhaust | Purple - white |
ASME A13.1 - 2007 Scheme for the Identification of Piping Systems - is intended to establish a common system to assist in identification of hazardous materials conveyed in piping systems and their hazards when released in the environment - concerns identification of contents of piping systems in industrial and power plants - recommended for the identification of piping systems used in commercial and institutional installations and in buildings used for public assembly.
• Design Strategies for Piping Systems
Piping systems design strategies - documentation, P&ID, flow diagrams - capacities and limits.
• Piping Codes and Standards
ASTM B819 Seamless Copper Tubes for Medical Gas Systems - Dimensions
Dimensions of copper tubes used in medical gas systems.
Condensate Generated in Cold Steam Pipes - SI Units
Huge amounts of condensate are generated when cold steam pipes are heated up must be drained from the pipes.
Condensate Pipe Lines - Sizing
Flow and pressure loss in condensate return lines - SI Units.
CSI MasterFormat Specifications
Construction Specifications Institute's 2004 Master-Format Edition.
Fluids - Identity Colors
Identifying colors used for fluid piping systems.
Insulated Steam Pipes - Condensate Generated (kg/h per 100m)
Heat loss from steam pipes generates condensate which must be drained from the system.
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
ISA Instrumentation Codes used in Process Control Systems
The ISA standards and symbols are important for the P&IDs and documents describing the process control system.
Plastics - Recycling Codes and Labeling
Symbol codes and labeling used for recycling plastic products like bottles, containers and packagin.
Plumbing Codes
Plumbing or sanitation codes are a set of rules and regulations imposed by cities, counties or states.
ISA process instrumentation codes - and combinations.
Refrigerants - Color Codes
Common refrigerants and their color codes.
Required Water Supply to Public Buildings
Water consumption and supply to public buildings.
Steam - Condensate Pipe Lines - Capacities (kW)
Maximum capacities for condensate pipe lines in kW steam consumption.
