Orifices - Natural Gas Capacity
Natural gas orifice capacities:
Drill Size (Wire Gauge) | Capacity | ||
(ft3/hr) | (Btu/hr) | (kW) | |
70 | 1.34 | 1340 | 0.39 |
60 | 2. 75 | 2750 | 0. 81 |
50 | 8.35 | 8350 | 2.5 |
40 | 16.55 | 16550 | 4.9 |
30 | 28.50 | 28500 | 8.4 |
20 | 44.75 | 44750 | 13.1 |
- Pressure 3.5" water column
- Energy content 1000 Btu/ft3 natural gas
• Gases and Compressed Air
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Density of Gases
LNG - Liquefied Natural Gas
LNG or Liquefied Natural Gas.
Natural Gas - Equipment Consumption
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Natural Gas - Pipe Sizing Calculator
Calculate capacities and dimensions of natural gas pipe lines.
Natural Gas Laboratory Consumption vs. no. of Outlets
Natural gas consumption in laboratory outlets.
Natural Gas Pipes - Low Pressure Capacities vs. Size
Sizing low pressure natural gas pipe lines - Imperial units.
Natural Gas Piping - Sizing of Low Pressure Pipes vs. Capacity
Sizing low pressure natural gas pipe lines - Metric units.
Natural Gas Piping - Sizing vs. Capacity
Sizing natural gas pipes - pressures above 5 psi (35 kPa).
Orifice Air Discharge vs. Pressure
Nozzles discharging air volume.
Steam Flow - Orifices
Steam flow through orifices - for steam pressures ranging 2 - 300 psi
Steam Leaks through Orifices
Steam leaks through orifices for pressures ranging 250 - 600 psi
