Oils - Melting points
Melting points of some common oils:
Oils - Melting Points
Oil Melting Temperature
(oC)
Butter 32 - 35
Castor Oil -18
Cocoa butter 34
Coconut Oil 25
Cotton Seed Oil -1
Lard 41
Linseed Oil -24
Margarine 34 - 43
Mutton Tallow 42
Olive Oil -6
Palm Kernel Oil 24
Palm Oil 35
Peanut Oil 3
Rapeseed Oil -10
Sunflower Oil -17
Soybean Oil -16
Tung Oil -2.5
Material Properties
Melting and Freezing Points
Liquid Densities
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Oil Pipes - Pressure Loss vs. Oil Flow
Pressure drop in oil pipes - viscosities ranging 100 - 600 Saybolt Universal Seconds.
