Moist Air - Transforming the Mollier Diagram to a Psychrometric Chart - or vice versa
A Mollier diagram express the same psychrometric properties as a psychrometric chart. Both presentations are very useful when designing air condition systems, drying processes etc.
The process of transforming a Mollier diagram to a psychrometric chart - or vice versa - is shown below.
- first - it has to be reflected - flipped - in a vertical mirror
- second - it must be rotated 90 degrees
• Air Psychrometrics
Basic air changing state processes - heating, cooling, mixing, humidifying and dehumidifying by adding steam or water - psychometric diagrams and the Mollier charts.
Air - Psychrometric Chart for Standard Atmospheric Conditions - Imperial Units
Psychrometric chart to analyze air properties, including temperature, humidity, enthalpy, and dew point at barometric pressure 29.921 inches of Mercury and temperature ranging 20oF to 120oF.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Heat Recovery Efficiency
Mixing of Humid Air
Moist Air - Cooling and Dehumidifying
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
Moist Air - Psychrometric Chart for High Temperatures at Sea Level
Psychrometric Chart in I-P Units for high temperatures at sea level and with a barometric pressure of 29.921 inHG.
