Logarithms
The logarithm (log) is the inverse operation to exponentiation - and the logarithm of a number is the exponent to which the base - another fixed value - must be raised to produce that number.
The expression
ay = x                                   (1)
can be expressed as the "base a logarithm of x " as
loga(x) = y                               (1b)
a = base
x = antilogarithm
y = logarithm (log)
Example - Logarithm with base 10
Since
103 = 1000
- then the base 10 logarithm of 1000 can be expressed as
log10(1000) = 3
Natural Logarithm - Logarithm with base e (2.7182...)
ey = x
e = 2.7182.... - e constant or Euler's number
Base e logarithm of x can be expressed as
loge(x) = ln(x) = y
Logarithms
SystemLog to the base ofTerminology
loga a log to base a
log10 = lg 10 common log
loge = ln e = 2.718281828459.. natural log
log2= lb 2 log to base 2
Rules for Logarithmic Calculations
loga(x y) = loga(x) + loga(y)                     (2)
loga(x / y) = loga(x) - loga(y)                   (3)
loga(xp) = p loga(x)                        (4)
loga(1 / x) = - loga(x)                        (5)
loga(b) = 1                        (6)
loga(1) = 0                        (7)
loga(0) = undefined                          (8)
loga(x < 0) = undefined                       (9)
loga(x) = logc(x) / logc(a)                     (10)
loga(x → ∞) = ∞                           (11)
Example - Logarithm Product Rule
log10((5) (6)) = log10(5) + log10(6)
= 0.6990 + 0.7782
= 1.4772
Conversion of Logarithms
lg(x) = lg(e) ln(x)
= 0.434294 ln(x)                           (12)
ln(x) = lg(x) / lg(e)
= 2.302585 lg(x)                          (13)
lb(x) = 1.442695 ln(x)
= 3.321928 lg(x)                         (15)
Log10 (x) and Loge (x)  for x ranging 1 to 1000
Basics
Mathematics
Algebraic Expressions
Principal algebraic expressions formulas.
Amines, Diamines and Cyclic Organic Nitrogen Compounds - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of the conjugated acid of amines, diamines and cyclic organic nitrogen compounds, shown together with the molecular structure of the acids.
Constants of π
The mathematical π constants.
Constants of e
The mathematical e constants.
Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Exponents - Powers and Roots
The laws of fractional and integer exponents.
Factorials
The product of all positive integers.
Fractions
Law of fractions
Inorganic Acids and Bases - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of inorganic acids and bases, as well as hydrated metal ions.
Laws of Indices
Simplifying calculations by involving indices.
Numerical Constants
Some numerical constants.
pH - Basic (alkaline) vs. Acidic
Introduction to pH - the acidic and basic (alkaline) definition.
Phenols, Alcohols and Carboxylic Acids - pKa Values
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
Polynomial Equation of nth Degree
The polynomial nth degree equation.
Scientific and Engineering Terms - ANSI Abbreviations
Abbreviations for Use on Drawings and in Text - ANSI Y1.1.
Signals - Adding Decibels
Solving Quadratic Equation with One Unknown
How to solve a quadratic equation.
Sound Pressure Level
Sound Propagation - the Inverse Square Law
Doubling of the distance from a noise source reduces the sound pressure level with 6 decibel.
Spherical and Cylindrical Coordinates
3D cylindrical and spherical coordinate systems
Trigonometric Functions
Sine, cosine and tangent - the natural trigonometric functions.
