Latitude and Longitude Converter: Convert Between Degrees, Minutes, Seconds, and Decimal Units
The Latitude and Longitude Converter makes it easy to convert between different formats of geographic coordinates: degrees, minutes, seconds (DMS) and decimal degrees. When working with GPS data, mapping tools, or scientific research, this converter simplifies the process of translating coordinate systems.
Decimal Degrees Units to Degrees, Minutes and Seconds Converter
Latitude : deg min sec
Longitude: deg min sec
The latitude is the angle formed by the equatorial plane with a line connecting the point of latitude to the center of the Earth. By design the values are between -90° and 90°. Latitude is 0° at the equator and on the northern hemisphere the values are positive. On the southern hemisphere the values are negative.
For longitude there is no natural reference like the equator for the latitude and the longitude reference has therefore been set to the Greenwich Meridian through the Royal Greenwich Observatory in London. The longitude is the angle formed by the half plane formed by the axis of the earth and passes through the Greenwich meridian and the half-plane formed by the axis of the earth and passing through the point.
Use positive longitude values east of London (max 180°) and negative longitude values west of London (min -180°) in the converter.
Degrees, Minutes and Seconds to Decimal units Converter
Convert to decimal degrees.
Latitude : (degrees)
Longitude: (degrees)
Examples of Conversion:
DMS to Decimal Degrees:
- 63° 30' 22.1178" N, 9° 12' 3.276" E => 63.506144, 9.20091
Decimal Degrees to DMS:
- 63.506144, 9.20091 => 63° 30' 1178" N, 9° 12' 3.276" E
Acceleration of Gravity vs. Latitude and Elevation
Acceleration of gravity due to latitude and elevation above sea level.
Builder's to Surveyor's Measurements
Convert builder's measurements to surveyor's measurements.
Distance between 3D Points
Distance between two points in a three dimension x, y and z coordinate system - online calculator.
Minutes to Decimal Hours Conversion: Chart & Calculator
Convert minutes to descimal hours.
Minutes vs. Degrees - Converting Chart
Convert from minutes to degrees.
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Radians vs. Degrees - Definition and Conversions
Satellites in Orbit
Orbital and escape velocity for geostationary satellites.
Solar Radiation - Daily Surface Energy
Daily surface energy from solar radiation.
Unit Factor Method
UTM to Latitude and Longitude Converter: Convert UTM Coordinates to Geographic Coordinates
Free online UTM to Latitude and Longitude coordinates converter.
