Hydropower
Online Hydro-power Calculator
The calculator below can be used to calculate available hydroelectricity power.
The theoretically power available from falling water can be expressed as
Pth = ρ q g h (1)
Pth = power theoretically available (W)
ρ = density (kg/m3) (~ 1000 kg/m3 for water)
q = water flow (m3/s)
h = falling height, head (m)
Download and print Hydro Power vs. Volume Flow and Head chart
Example - Hydro-power
The theoretically power available from a flow of 1 m3/s water with a fall of 100 m can be calculated as
P = (1000 kg/m3) (1 m3/s) (9.81 m/s2) (100 m)
= 981 000 W
= 981 kW
Efficiency
Due to energy loss the practically available power will be less than the theoretically power. Practically available power can be expressed as
Pa = μ ρ q g h (2)
Pa = power available (W)
μ = efficiency (in general in the range 0.75 to 0.95)
Energy from Hydro-power
The potential theoretical energy in a volume of elevated water can be calculated
W = m g h
= ρ V g h (3)
W = energy (J)
m = mass of water (kg)
V = volume of water (m3)
Example - Energy in Elevated Water Volume
10 m3 volume of water is elevated 10 m above the turbine. The potential energy in the water volume can be calculated as
W = (1000 kg/m3) (10 m3) (9.81 m/s2) (10 m)
= 981000 J (Ws)
= 981 kJ (kWs)
= 0.27 kWh
Potential Energy in a Tank or Reservoir
You can estimate the total energy in a tank or a reservoir where the surface area varies with elevation - as typical in a natural reservoir - by integrating the potential energies for horizontal segments as done in the template
Copy the document to your Google Drive or download it as a spreadsheet to make your own calculations.
• Environment
Energy Accumulated in Heated Water - kWh
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Heat, Work and Energy
Heat vs. work vs. energy.
Required power to pump water.
The Mechanical Energy Equation compared to the Extended Bernoulli Equation.
Potential Energy - Hydropower
Static Pressure vs. Head
