Gaskets - Temperature Ratings
Temperature ratings for some commonly used gasket materials:
Gasket MaterialTemperature Rating
(oF)(oC)
EPDM -30 to 230 -34 to 110
Nitrile -20 to 180 -29 to 82
Neoprene 30 to 180 -1 to 82
Fluoroelastomer 20 to 300 -7 to 149
Silicone -30 to 350 -34 to 177
Dimensions of Pipes and Tubes
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
DIN - Valve Standards
An overview of DIN - Deutsches Institut für Normung - valve standards.
Elastomers
Natural and syntetic rubbers guide.
Gasket Characteristics
Gaskets are used to make a fluid or gas resistant seal between two surfaces.
Japanese industrial flanges, bolts, nuts, and gaskets standards and specifications from JAS - the Japanese Standards Association.
Pipe Flanges and Gaskets - Dimensions
Gasket dimensions according ASME B16.5 Pipe Flanges and Flange Fittings.
