Float Glass - Weight vs. Thickness
Weight of float glass:
Thickness
(mm)
Weight
(kg/m2)
3 7.5
4 10
5 12.5
6 15
8 20
10 25
12 30
15 37.5
19 47.5
25 62.5
  • Float glass is a sheet of glass made by floating molten glass on a bed of molten metal.
Material Properties
Solar Heat Transmission and Type of Glass
Relative solar heat transmission through different types of glass windows
Windows - Inside Condensation
Water condensation on inside glass windows surfaces vs. outside temperature and inside temperature and humidity.
