Excavation Slopes
Excavation Slopes
Excavation Slopes vs. Type of Soils
Type of SoilSlope
(x : y)
Solid rock, shale or cemented sand and gravels 0 : 1
Compact angular gravels 1/2 : 1
Recommended slope for average soils 1 : 1
Compact sharp sand 1 1/2 : 1
Well-rounded loose sand 2 : 1
Example - An Excavation in Sharp Sand, 10 ft deep
Excavation in sharp sand should be sloped 1 1/2 unit for each unit depth.
(10 feet) (1 1/2 feet/foot) = 15 feet
Miscellaneous
Content in Horizontal - or Sloped - Cylindrical Tanks or Pipes
Volume of partly filled horizontal or sloped cylindrical tanks or pipes - online calculator.
Slope Calculator: Convert Between Degrees, Gradient, and Grade
Convert slopes pitch between degrees, gradients and grades.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Soil - Water Content
Water or moisture content in soil.
Soil and Rock - Bulk Factors
Trench Excavation
Estimate trench excavation - online calculator.
